Car Revs Drop And Come Back Up
SKYTYM
 Share
yeh when i went from an atmo bov to the stock one again it kept idling really bad. tried clening aac valve and afm and a couple of other things
then reset ecu and it was all good
no for fear of repeating myself to many times ill end it here lol
as for the AAC valve location, i looked it up again (it's been about 3 years since i had my 33 so i'm a bit rusty on locations of things). the AAC is attached to the side of the IAC. if you look at the back of the plenum you will see a round cylinder about 1 inch wide pointing towards the passenger side with a plug on it, and just behind it what looks like a really long nut with a plug in the end of it. the round cylinder is the AAC solenoid. the other is the IAC. you remove the whole unit with 3 bolts (i think they are 12mm, maybe 13mm) and 1 or 2 of them are located under the unit. then disconnect the plugs and hoses. the AAC i think is held on by 2 small phillips head screws. give the whole unit a good spray with carby/throttle body cleaner. then stick it back together and install the unit back in the car. after doing this it is best to readjust the idle which you need to lock the car into base idle mode. this can be done without a consult but i can't remember how. has something to do with bridging 2 wires in the consult plug.
This man knows his stuff, listen to him.
I can say from yesterday's experience it's a 10mm bolt.
I did the aac clean and adjusted my idle... I'm idling at 700 now and it doesn't drop to nearly stalling anymore when going from say 4th gear -> neutral. Wicked.
Hey Dudes and Dudesses Well i changed my fuel filter and spark plus and clean the the body with carby spray and then my idle problem went away. But then just yesterday another problem happened my car felt like its lost 20-30% power and it sounds like a WRX, when i go over 4gran it trys to find it self but sounds really f**kt up it really rumbles like a WRX engine. I dont know if its an exhaust problem or a engine problem gonna go to the mechanics today to check it out. Bloody hate spending money on problems :D
 Share
    • You will need custom pistons made, the combustion chamber is to modified for any off the shelf piston to give a good compression ratio
    • Which is a thing done by no-one ever. Not even remotely a good idea. I would run an engine with 10:1 these days. Good management and fuel compared to the early 90s when these boat motors were designed & built.
    • I think you misunderstand. This was Greg driving from Melb to Syd (or return) at a constant 100km/h on the highway. Very little throttle movement, very little accel/decel. You should be able to get 8.5 l/100km under those circumstances (which is effectively what he reports - 50L for 600km is 8.3 l/100km). I drive my car to & from work every day, in traffic, on a mixture of 50, 60, 90 km/h roads (and therefore at up to 110km/h!!) with traffic lights and freeway sections. 28 km each way, so about a 30-40 minute drive depending on day, direction and traffic (which is enough for the majority of the drive to be "fully warmed up". I typically get flat 10 l/100km every single week. OK, maybe 10-10.5, every single tank of fuel. RB25DET Neo. It is easy to get acceptable economy. I won't say "good" economy, because modern cars are doing 5-6 l/100km in the same conditions.
    • Superpro are fine. There are some applications (R32 FUCAs for example) where they are no damn good, but typically for any normal suspension bush, they are fine. Some people will complain of them making noise. Some people will complain of them collapsing. But many of those can probably be traced back to not properly lubing at install or other installation problems, or possibly other problems elsewhere in the suspension that put additional load into particular bush. And for the legit complaints? Meh. Deal with it. I had to replace the poly bushes in my R32 FUCAs every year. The real issue is that I am sold on the idea of adjustability of at least upper arms. So I only have spots for poly bushes in lower arms these days, as everything else is either hardened rubber or spherical steel.
    • Suspension really is complicated.... All these considerations are making me over think it all. Again. I reckon I'll wait for SK's response on his coilovers, and go from there. Though if I go MCA, I'll have to decide on whether the extra $600 (voston comforts $1890, mca pro comfort is $2490) is worth it. Just something soft and comfy, yet firm enough when required at the track or a casual old pac drive for a pie... Otherwise, anyone have experience with SuperPro bushings? Needing to replace the bushings on the suspension department... Will probably keep the oem uppercontrol arms etc, and just replace the bushings.
