M35 Stagea 4wd Light On..
BezerkR32
 Share
4WD light on dash cluster is on all the time. Has been since i bought the car. Didnt think anything of it until lately.
Was wondering if it was normal or if it might be indicating a transmission fault. Car seems to drive fine.
Any help much appreciated.
check the attesa fluid in the boot, its behind the hidey-hole on the drivers side. i bet you the fluid is low.
+1, this was my first thought. That little cubby was a bugger to get out in mine, thought I was going to bust it, then it finally popped free.
ahh good, thanks for letting me know that. ive never taken mine off, i should because i get the 4WD light sometimes (must be fluid, only happens on inclines)
the book lists the g-force sensor as a potential fault, fluid, make sure the 'S' light appears next to the 4WD light on the dash if you move the switch.
also check the plugs to the attesa ecu which is next to the fluid bottle
where abouts is the bottle? lol i had a quick look but couldnt see anything
It is in the boot. On the right side is a small hatch on the side wall (similar to the one on the left). To get to the attesa bottle you need to remove the front cover and the whole side compartment (black plastic inset). To remove this it is easiest done with a small (thin) screwdriver or similar. There are latches in the top corners of this inset box. By pressing down on the top of them you will be able to pull the box out. You will the see the Attesa bottle.
Good luck
Andy
After 6 months ours started displaying the 4WD warning too. It is never on just after start-up but will display anytime within the first minute. Usually if it doesn't come on within a minute it won't come on at all.
So I bled and replaced with Matic D in the Attesa system and replaced oils in transfer case and both diffs. Problem remained.
Sometimes I can sense that the warning light is about to display. When driving away the car will bind up slightly and want to straighten up - like as if the centre diff is locked and the fronts what to rotate at the same speed as the rears. The warning light will come on, the steering will relax, and I guess it then is a rear-drive only?
Also, if the car has been allowed to fully cool then the warning light won't display but is very likely if the car was recently switched off.
My next attempt will involve reading those fault codes.
  • 4 weeks later...
  • 4 weeks later...
put the car on our scanner at work and it displayed a 4wd motor fault. im guessing this is the pump motor in the boot. Can anybody confirm this.
Yeh pretty sure it's under the back on the RHS .....right behind the rear wheel.
P.S. Any chance I can get on that scanner......I think I may have the same problem :D
Edited by Jetwreck
sure, no problems, just give me a call. 0425 349 923
P.S. Any chance I can get on that scanner......I think I may have the same problem :(
  • 3 months later...
I have recently had the same problem on my NM35.
My 4WD light was coming on after a few minutes of driving. This then turned into every time i started the car the 4WD light would be on.
While the 4WD light is on the ATESSA is not active so it will be running in RWD.
The problem end up being (after a long time troubleshooting) a relay located under the air filter. This relay controls the ATTESA pump. Without the pump no 4WD.
This relay in not available threw Nissan anymore so i had to addapt a generic 40A relay.
This has fixed the problem completly and 4WD light has not come on again and ATTESA is working perfectly.
I have attached some schematics that helped me out.
I hope this helps someone out as i spent ages figuring this out.
Cheers
  • 5 years later...
Cheers
Thanx sooo much for posting this. It fixed my car. I bought my car from a Sydney Importer & the 4WD light came on 2 weeks after I got it. His Mechanics looked at it once then they told me to go somewhere else the next time. I found this and took the car to my mechanic, who checked through the whole system then the relay and it was dead. He wired in a 40A generic and BOOM attesa pump fired up and no light.
 Share
    • This is completely different to their OG approach. I have the R&D/guinea pig  set of MCA Blue coilovers in my stagea from about 9 years ago. Josh started with a rough R33 spec valving figure and spring rates (which was 10/8kg). We went for a whiteknuckled test drive through the Landsborough hinterland before he decided needed more valving and less spring. Eventually settled for 7/5kg springs and a bunch more valving (unsure of figures). I was running on some Tein Superwagon coilovers at the time and the difference was night and day. And after going for a ride with a fellow stagea chum who runs BC golds, i still believe the MCA Blues i have are still by far a better ride. As for Voston, as far as i am aware, that is their budget brand and nothing like the Pro series they offer now, or anything like the Blue/Red or Gold series back in the day
    • I had teins on my Forester turbo, loved them to a degree because of the EDFC.  Well 2yrs ago my son realigned my suspension geometry for me resulting in two non serviceable coil overs. Was not going to replace with more teins as I hated the ‘crunches’ and through your spine stiff as a mofo impacts. So, I spoke to MCA and they set me up with some soft street duty coil overs for about $2,400. Night and day but still on the stiffer side
    • I'd verify how invested in exactly 9.5 he is if it turns out to be a massive amount more effort to go 9.5 vs 9.0 or 10.0.  He may have just said that as a suggestion not realising it'll be a huge deal to go specifically there when half a point either side isn't so bad.
    • Absolutely baffles me why they deleted the forum. the facebook group can be kind of helpful, but you get too many bellend's spreading the wrong information.
    • I think so, I'll have a look when I'm home later. I wrote a post on the now defunct Haltech forum detailing this, very useful they deleted it lol.
