Tokyo As 2010
we go every year, and its always good fun
Newera are given press passes , which allow you into the hall before the masses
allows you to go talk to the exhibitors and to look up close at the cars, before everyone else does.
Moving through the hall, there were move delights on show, including the cars ;-)
This was my favourite stand ….the guys at hks kansai are great
They are even doing some custom work for my r34 which is on their demo car…but because we asked nicely they are going to produce it for me …wahoo!
r34 features the nismo z tune front and rear arch trims
Under bonnet
R35 demo car – expect to see group guys on these shortly
New r35 water cooler
New r35 lsd in development
New tomei rb28 set up
New turbo set up for r32-34 gtr – 300bhp output each
Gtr muffler will follow in same style , r35 one being developed in conjunction with new era japan and tomei
New wheels from bbs
Hasemi grtr demo cars
Coolest stagea ever….
Runs an rb26 d jetro
Wicked ae86
  • 2 months later...
aawesome!
+ 11 ty.
this thred delivers, passed by a few times but i thought id comment. hakosuka stagea makes me spew in my mouth but i luv the nismo xanavi super gt car. hoping to get back to sepang circuit or even fuji in a few years. great range of cars and parts. more pls. btw i heard about the nur RB28 v-cam top secret R34 GTR. nice one, i remember the 1003hp R33 in Maxx Power magazine from the UK. i like rare expensive stuff.
Edited by dirtyRS4
 Share
    • swaybar swaybar swaybar swaybar swaybar anyway OP, what is currently in your car, are they factory shocks and sway bar? Any sign anything else has been changed under there over the years? And as Murray said....what are effect you looking to change
    • Congratulations on your find  Did you mean it has 6k miles or was that a typo? Firstly, keep in mind some movement of the shifter is normal...it is a long rod hanging out of a box bolted to the engine. Having said that there are 2 next places to look: 1. Transmission and engine mounts. If these are worn or broken the shifter will move around more. They are reasonably easy to source and replace on a hoist, and possible but uncomfortable to replace car stands 2. On the bottom of the shifter there is a nylon cup that sits over shifter's ball end. If this is worn or broken the shifter will move around more than it should (but will still shift OK). That is a cheap part and requires removal of centre console, rubber shifter hole covers and a circlip in the gearbox shifter hole to remove the shifter. Re maintenance, as with any new import you should change all the fluids including transmission when you get it; never trust the seller and previous owners to have done the right thing. I am pretty sure R34 GTT is the same as earlier big box transmissions, so use any good quality GL4 75w90 trans fluid if it is shifting well (if it is hard to shift due to synchro wear, redline shockproof lightweight will keep it alive a bit longer before rebuild is required)
    • Well considering I have the exact same problem with that as the original one I don't think that the ignitor is the problem. I would imagine that this being such an uncommon problem the possibility of getting a new ignitor that is bad in the same way as the old one has to be very slim. I'll definitely pull everything apart this weekend and check the turbo out. Got quite a bit of things to check out Saturday like fuel pressure and the pcv so I'll report back once I do that.  Thanks everyone for all the replies this is all really helpful
    • Rb's have issues with bottom end starvation, not head starvation. Which either way, you probably wouldn't ever see on a dyno. Strange... What's pump gas for you? Octane rating?
