This Is The New Recipe Chat Thread...
Houdini
 Share
Tring to buy a R32 GTR RB26 front cut, only probably is tring to find somewhere to store it for a month or 2 without the wife finding out!!!
Any idea's
If my car doesn't sell soon i'll sell ya the 26 from mine with the loom to go straight into your stag.
Any idea's
Also bought some fancy brake fluid
Send wife? PO Box 2161 Boulder WA :) Or has this already been suggested? Sorry, haven't read whole thread.
OK.....I'll bite.
Cooling
HDI FMIC
Phenolic runner spacer
Nismo low temp thermostat
Custom(fisher) 3" intake
V35 manual radiator
Twin Trans coolers
TB spacer(lol)
Powerduct( :D )
catch can(s)
Turbo
High flow original to GT30/71
HDI EBC
Handling
Bilstein shocks
Eibach springs
324mm DBA rotor
R32GTR callipers with brackets
Hawk pads cut to size
Body
19" Lenso rims
R33 GTR N1 scoops
fully sic Nismo strips(custom fading ;) )
eyelids
Exhaust
Dump pipe....some japanese one
Complete Exhaust from Charlstone
ECU
Haltech platinum interceptor.....soon to go for a replacement reflashed ECU
Interior
Twin headrest DVD players
DTV
English conversion
On the horizon
Sway bars
Custom Airbox Suction pipe setup
Brembo's
Paddleshift's
Gearbox rebuild with stage 2 shift, 3,500 stall(depends on reflash outcome) and MVB
Bonnet pin's so I can lock the bonnet closed and give the key to my wife to STOP ME!!!!!!!!!
Edited by Jetwreck
I put the new cover on the motor, just got it back from the powder coaters.
unfortuntely at the same time I found the old cam breather hose had a split so it has a temporary blue replacement.
That looks awesome
That looks awesome
I'm guessing you don't mean the crappy blue breather!
Great work again from Craved Coatings on the cover... I picked up the cover on SAU, it was hand sprayed from a can. Craved sand blasted then powder coated in in crinkle finish black - looks mint :P
I was gonna ask where you got that coilpack cover from, Duncan - good find!
And yeah, Chris @ Craved Coatings is doing some awesome work, and he's definitely putting the hard yards in! I think he sleeps (much) less than I do!
I finally got rid of the stock exhaust, to replace it with a 3" X-Force stainless steel system, with a new dump pipe and 3" high flow cat con.
The guys at C-Red even gave me a silencer with it if the neighbors complain ^_^. Idont know why i didnt do it sooner! ^_^
That black bit on the cam cover is dear as poison. Just got one from Nissan. Nearly $40.
Luv that cover.
Edited by 66yostagea
 Share
    • I think the pic in the first post is another car, and post 7 is OP's car with standard arms and swaybar swaybar swaybar. I can't tell what brand the silver coilovers are, and even if I could I don't know whether the spring rate is OK, if you can find a brand on the shocks and numbers on the springs that might help. Also, if you can measure the ride height from centre of your wheel to the guard that will help with advice too as handling suffers if ride height is too low
    • sadly, pics no work. that car must have spent a lot of time in a cryo bubble
    • In the first photo you posted, the colour of the control arms are the signature colour for Ikeya. Same for the swaybar, signature colour for Whiteline.  I like Hardrace, they also do hardened rubber bushes if your car is mainly a street car.  I like GKTech as well, but they use a lot of rose joints in their stuff so might not be the best choice for everyone.  The system might have been good back in its day, but it's a prehistoric system now. I suspect that most people have removed the HICAS as they want the car to do what they want to do, not what the car wants to do. From what I also understand, it isn't consistent in it's behaviour on track so it's hard to trust the car/know where its absolute limits are for track use.  Having said that, I think the HICAS eliminator kit was the first thing I installed when I bought my car. I don't personally have any experience with the HICAS system on a race track.
    • Thanks for the info. Didn’t know I had aftermarket control arms already? Will talk to my garage. What brand would u recommend if I want to play around with my camber more? I would think my camber is around stock level right now or more negative now due to lowering with coilovers. I will be lower her again 1.5 cm to get some more.    also why does everyone like to remove the hicas system? Is it because most don’t work properly anymore or ppl just don’t like them. Mine is functioning as it should be right now.    thanks for the good info
    • It looks like you've got Ikeya control arms and an aftermarket sway bar, maybe whiteline?  Or am I just going crazy? lol Unfortunately it won't, but what it will do is look really pretty. That's about all unfortunately.  How much neg camber do you currently have? Generally lowing the car dials in quite a bit of neg camber as it is. If you do go down this path, your best bet is get adjustable arms, toe arms (or preferably a good HICAS elimination kit) and traction rods. With all 3 being adjustable, you'll be able to dial out any bump steer that is introduced by playing with the camber settings.
