New Garrett Gtx2860R / 2863R / 2867R
Gav
If you share that 3.5" exhaust between the 2 GTX63s it is only 1.75" diameter exhaust for each 440hp turbo!
That's a huge ask from 1.75"
That Z32 shows its doable just open up the inlet and exhaust more and if it doesn't work then I'll right them off.
But for now there my 600 wheel horsepower turbo of choice
Edited by mr skidz
Front housing machining has been done on my GTX2860's, picked them up from MTQ this morning.
I'm about to do a multi week roadtrip down to Victoria, so they won't be going in for a little while. I'm hoping maybe January. I need to sort out a few things first, like fuel system and exhaust.No point putting them in if something else is holding them back.
  • Like 3
Gorgeous wheels pete, how much power are you aiming for?
E85?
Just spin them as hard as you can too..
I've been held up by my machinist he hasn't given me my head back yet so I'm able to delay my turbo choice.
Edited by mr skidz
As above, they're -5 housings so .64 ar I believe.
And yes, e85 of course!
Power wise, that's to be determined by my work outlook. Worst case I suppose would be standard engine with arp headstuds. Id still throw a heap of boost in but may be limited
  • Like 1
Nothing wrong with the standard bottom end, as you said just wack a set of ARP2000 studs and also maybe some drop in cams and away you go!
  • Like 1
One for you pete, GTX2860's custom high mounts on a std 2.6L pulled 373 rwkw on only 17psi using stock ported comp covers and says .73 turbine housings??
Definitely different
https://instagram.com/p/77nQx7FHfn/
Edited by mr skidz
Does any body know if a -9 rear housing will work with the gtx cartridge? Wheels are the same diameter just a different trim, 76 vs 62. As i have -9's now was wondering if i just got the machining done and swaped out the cartridges.
edit: Looks like the -9 rear exducer is 34mm while the -5 is 41mm so I'm guessing no, only other question is will a gtx2860 front compressor fit on a 2859r cartridge?
Edited by fomby639
