Nismo Engine Mounts
Hey guys,
Had a quick hunt around but couldn't find anything definitive.
Was looking at changing engine mounts in my R34 GTT at some point (when they wear a bit more) and wanted to know if anyone has advice on using the Nismo mounts or going with stock Nissan ones. I know there obviously stiffer and all that, but what real world difference is there? How much vibration increase is there? And do you feel any more engine torque through the car body as the engine twists?
Thanks
The Nismo Competition Parts Catalogue states,
"By increasing the hardness of the rubber used in the mount bush, resistance to damage is naturally increased, as is engine shake and lean during acceleration/deceleration, braking and cornering: this provides improved accelerator response, shift feeling and cornering performance".
If they accomplish the above, my only additional comment will be that there should be less heat in your tyres.
I've gone from stock rubber bushing to cusco polyurethane ones in my S13. the engine response is fantastic cos it hardly "rocks" anymore and all the power is transmitted immediately to the transmission BUT ur chassis will vibrate more too (low freq vibrations)...u can see it in your side and rear view mirrors. After a while i hardly noticed it anymore... but some ppl might find it nauseating?
as for the nismo ones... its definitely stiffer than stock....but for the price, i personally dont find it worth it. thus i went for the cheaper and even stiffer cusco ones
Edited by C4a0s
  • 1 year later...
So after looking through threads, some say it will raise the engine. Some say it won't. I already have a engine damper, I'm wondering if I should go nismo or oem. The price difference is not a factor, there's a 40$ difference. I'm leaning toward the Factory because i don't wish to have clearance problem, but I thought it would be fair to take 5 minutes and make sure I make the right move :)
Thanks!
 Share
    • In the first photo you posted, the colour of the control arms are the signature colour for Ikeya. Same for the swaybar, signature colour for Whiteline.  I like Hardrace, they also do hardened rubber bushes if your car is mainly a street car.  I like GKTech as well, but they use a lot of rose joints in their stuff so might not be the best choice for everyone.  The system might have been good back in its day, but it's a prehistoric system now. I suspect that most people have removed the HICAS as they want the car to do what they want to do, not what the car wants to do. From what I also understand, it isn't consistent in it's behaviour on track so it's hard to trust the car/know where its absolute limits are for track use.  Having said that, I think the HICAS eliminator kit was the first thing I installed when I bought my car. I don't personally have any experience with the HICAS system on a race track.
    • Thanks for the info. Didn’t know I had aftermarket control arms already? Will talk to my garage. What brand would u recommend if I want to play around with my camber more? I would think my camber is around stock level right now or more negative now due to lowering with coilovers. I will be lower her again 1.5 cm to get some more.    also why does everyone like to remove the hicas system? Is it because most don’t work properly anymore or ppl just don’t like them. Mine is functioning as it should be right now.    thanks for the good info
    • It looks like you've got Ikeya control arms and an aftermarket sway bar, maybe whiteline?  Or am I just going crazy? lol Unfortunately it won't, but what it will do is look really pretty. That's about all unfortunately.  How much neg camber do you currently have? Generally lowing the car dials in quite a bit of neg camber as it is. If you do go down this path, your best bet is get adjustable arms, toe arms (or preferably a good HICAS elimination kit) and traction rods. With all 3 being adjustable, you'll be able to dial out any bump steer that is introduced by playing with the camber settings.
    • Great discussion guys. I just have coil overs in my car right now. Ride is pretty stiff and everything feels very precise and accurate when hitting the corners. I started off with a high level and kept specimen.   the only item I feel I might need to adjust is my camber with control arms or a kit as I might want to tuck in my rims more so there is no rubbing. Otherwise I have not thought too much into it as quite happy with the setup. I think the bushings are all good still.    My motor is currently out now but I have got a nismo front strut bar to install. So that should help with body roll in front.    added a photo of what I started with before the modding or let’s say modernization of parts started. 😂
    • Thank you both, much appreciated. Yes, 6k miles, not a typo lol. The underside, engine bay, engine, trunk, interior, etc., look great and super clean, has all the splash guards too. Not sure if you can expand the photos, but the dash pic shows the ODO. She looks brand new, inside and out, even has the original Nissan TV/DVD/Nav head unit; still thinks it's in Tokyo haha! I used to own a '94 MKIV Supra, sadly sold it years ago, but wow I love the Skyline so much! The R34 gets SO much attention here since they just became legal to import last year.
