Transfer Case Fluid Change W Attessa
GH05T
 Share
hi all,
doing some of the fluids on my stagea with a service
SII C34 RS4S manual AWD
engine oil and diff fluids done.
the transfer case uses the Atessa system and i have been told its not just drop fluids and refill but rather its a specific bleeding system?
it has the line which runs up into the wagon back into a seperate reseviour for the atessa.
one, how do i properly change the fluid and
two, what fluid is recomended? should iu just use genuine nissan powersteering fluid?
Re: fluid
The letters in brackets are the Nissan certifications. I use the Valvoline as its well priced and synthetic.
Nulon Synth ATF (C D J K) 66.50/4L = $16.60perL
Valvo Synth ATF (D J K) 49.95/5L = $10.00perL
Transmax Z ATF (D only) 76.50/4L = $19.10perL
On the GTR theres a bleeder on top of the rear of the gearbox, and IIRC another near the diff somewhere. Workshop manual bleed method is you disconnect a wire in the drivers side footwell then reconnect over and over again. I've been told (by Duncan?) that you can just put the car up on stands with the motor running and crack the bleeders. Sounds like a much better option to me. Not sure if your attessa is the same.
as far as i know its the same as the R33 gtr system, but who knows they may have decided to throw some random eccentricitiesin there.
...On the GTR theres a bleeder on top of the rear of the gearbox, and IIRC another near the diff somewhere. Workshop manual bleed method is you disconnect a wire in the drivers side footwell then reconnect over and over again. I've been told (by Duncan?) that you can just put the car up on stands with the motor running and crack the bleeders. Sounds like a much better option to me. Not sure if your attessa is the same.
yes, yes and yes :)
if you really want to change it, just undo the line at the rear of the gearbox, let it drain out. replace that line (tight but not overtight, maybe clean up the thread and flare fitting because they are prone to leak if not perfect). Fill up reservoir. Start car (out of gear of course) and open bleeder at the rear of the box. If that doesn't bleed through properly you may need to open the second bleed which is above the driver's side rear axle, and hard to get to.
There should be a few guides on Attessa bleeding on here from a few years ago. As has been mentioned there s a plug under the dash that needs to be pulled to put the attessa in constant pressure mode. Then I just crack the front bleeder on the transfer and get someone else to fill the reservoir in the back.
I use my brake bleeding bottle and hose so as not to make a mess.
  • 1 year later...
So maybe unscrew it completely to see if it runs out that way?
From how I read the bleed procedure, the bleeder on the diff is gravity fed, so just crack it and wait until the bubble subside, top up reservoir and pull blled plug for attessa pump and switch ign on and crack front bleeder for a second and then turn ign off and repeat until no more air is present. Then plug in and prime system? does that sound about right?
 Share
    • Candid connections: Platform for casual relationships Authentic Maidens Supreme Сasual Dating
    • I would absolutely be starting with this idea over all other possibilities. It sounds f**ked.
    • Lighting in the shed looks real good! Not lying, have shed envy lol. Maybe one day I can fk off from Metro Sydney.
    • I would be cautious with those 2000/2200 CNG injectors, swap them out for a set of 1550 aka 1650 Bosch stainless ones before you take out a motor.
    • I tested them all a couple times, haven't tested it warm or wet though. The only seemingly really weird thing was the cylinders plug closest to the dash was pitch black nearly.  Doesn't smoke out of the exhaust or anything.    Also sorry everyone for the very late response. Got busy with work and all and didn't get around to fooling with the car for awhile.  But an update! I figured out the cause of the lean condition, my intercooler had at some point exploded or something. It's clearly separated in a spot with black oily buildup around the leak, and multiple leaks in various vacuum lines. I've replaced it and the vacuum lines, and gotten new clamps and there are 0 leaks now after doing a couple smoke tests.   The car now runs significantly better and the exhaust doesn't overheat anymore. I still have the main problem though where the engine feels like I'm lugging it around sub 3500rpm in any gear besides 1st, 2nd It's less noticeable but 3rd anything under 3.5k and I need to downshift or the engine is clearly struggling when trying to accelerate at all, 4th is the exact same, sub 3.5k engine won't accelerate and its hard to bring it back up to speed, 5th gear doesn't feel like the car is going to straight up fall apart now but it still can't pull 5th. It slowly loses speed and rpm and ANY gas I give I can feel the shakes from the engine and it slowly dying. If I ever so lightly give it gas it will slowly and nicely decel till around 2k rpm instead of lugging. But it cannot accelerate at all or maintain speed.   If I go from first gear at 5 or 6krpm and then shift to second it also feels like it's struggling to make power till above 3krpm if trying to accelerate but I can cruise around parking lots at around 1-2krpm just fine in 2nd. It's just when accelerating hard it and changing gear you really notice it die down.  But even if you shift at way lower rpms it does the same thing till somewhere above 3k.  As far as I'm aware it's got r32 gtr transmission gear ratios with gts4 diffs. The tire size is 205/55r16 91h Above 3500rpm the car pulls and runs and drives quite normally and the power from engine sounds and feels very smooth.  It's perfectly driveable at above 3.5krpm but I drive on the highway alot for work and it gets really bad gas mileage in 4th at 4.4krpm. Not that I'm looking for great gas mileage with such a car, just I'm sure being at around 3krpm would be significantly better for it.    Have appreciated all your guys help. I do understand the engine may just be f**ked from running with a boost leak though.    One final thing I'd like to add is I'm only shifting so high in the rpm range is because if I don't I will feel the engine lugging bad with 0 power in lower rpms, pretty much anytime off boost trying to accelerate it feels really bad.  Also when I say 3500 rpm I don't mean exactly. Just around there.
