Proxy Kill Switch
c34Florry
 Share
Ive recently been thinking about putting a killswitch in my stagea. Ive sat in the drivers seat and picked out 5 places I would look for one if I was to steal a car amd can't think of another convenient place to put it so im now thinking of a proximity sensor (like an rfid key tag amd a unit under the dash or similar wired up to the fuel pump). Has anyone done this or seen this done before? Also need it time delayed or run through the turbo timer. Does anyone know of a reputable alarm specialist in Adelaide that might be able to help out with putting my words into action? As I have a poor history of auto elecricianism.. Any help or guidance would be much appreciated :)
Random, but my old VL had a screw you had to hold your finger on while turning the key. I can PM the location to you of where it was, probably shouldnt announce it on here
As for how it was done... I have no idea. Screw with a wire off to somewhere. Car came like that so never bothered to check it out. It didnt have an alarm so must have just been utilising the stock electrics etc. Not sure it would even be an option on the VL.
It let everything turn on but the starter
I thhought it would have been like an rfid ignition system except hooked up to fuel pump. I still want to use the key to start
Edited by staglover
This looks like a handy device. It suggests putting it in the fuel pump line but you could use in a number of ways to disable the car:
http://www.trademe.co.nz/Browse/Listing.aspx?id=704435597
The reason I don't like that ^ is it's another remote that you need to carry around. And either you're going to put that on your keys, which ultimately defeats the purpose because most cars are stolen via the keys; or you need to have it separate to your keys, in which case where do you keep it?
I would prefer a completely separate device, and I don't care if it takes me 5 minutes to start my car every time I drive it. The harder it is for me to start the car, the harder it will be for any potential thieves.
Thats what I liked about mine. There was no need to carry anything extra, no button, was just (AFAIK) earthing out a circuit to enable the start circuit
It was probably just the earth side of the starter signal (from the key) to the screw so it had no earth till you put your hand on the screw and then on the key (grounded through the key switch) then the car would start. If you didnt know where the screw was, the car wouldnt start.
BUT this way you could still bridge the solenoid on the starter moter and get it going etc. So its not the best way to do it. But you might be able to do something similiar with the fuel pump circuit.
This is just an idea, not sure it would work in a skyline, and it might not be what you are looking for
Ive recently been thinking about putting a killswitch my stagea. Ive sat in the drivers seat and picked out 5 places I would look for one if I was to steal a car amd can't think of another convenient place to put it so im now thinking of a proximity sensor (like an rfid key tag amd a unit under the dash or similar wired up to the fuel pump). Has anyone done this or seen this done before? Also need it time delayed or run through the turbo timer. Does anyone know of a reputable alarm specialist in Adelaide that might be able to help out with putting my words into action? As I have a poor history of auto elecricianism.. Any help or guidance would be much appreciated :)
First things first, In the name of security, get rid of the turbo timer. They give thieving f#%ks the three wires needed to start your car!!!
In regards to kill switches, many years ago in a car I don't own anymore, I fitted one in the right hand air vent (between dash & drivers door) about 2 1\2" down the duct. It ment I had a 3" long thin bit of aluminum on my key ring. 3 attempts were made to steal it, but they never got it (it was a near mint XC Fairmont 378 stroker, top loader, 9" yada yada yada).
  • Like 1
the tag can be replaced by smartphone, it it acts like an rfid device
is it similar to what viper has..?
Edited by enka
  • 3 months later...
Forgot about this thread.. something im still really keen on..
Noted and have since done so.
you are really talking a custom solution. forget traditional car audio shops..
Ill have a hunt around for specialist I s'pose
As far as 'another remote', im imagining something like a supercheap club keytag sized myki thing that when within five meters of a receiver in cabin turns the immobilizer off. Start car like usual. Outside the radius, immobilizer on.
key pass over a sensor behind the dash
this could work Edited by c34Florry
I worked on a commodore that had a push button, to a second immobiliser I guess, under the carpet on the tunnel. It was a prick to find and get the car started even if you knew where it was.
 Share
    • I disconnected before the fuel pump and restriction still there. Disconnected at turbosmart fpr and also after ethanol sensor and pressure dropped. No kinks in line but I found one spot above diff that I can hear the fuel flowing while running so I'm wondering if there is built up corrosion  from 10 years of sitting.  I had injectors cleaned and tested and one was dead but rest were fine. Was never an issue when I owned the car previously but I'll talk to jez about his thoughts on if they should be changed to newer tech. Thx guys at least I know the setup should work again. Pump is wired directly to relay and not using factory plug any  more
    • Nice work on the shroud/ducting.
    • Hi and best of luck with your car. Its a bit hard to tell how low the car is all round from that pic or if its been lowered or not. 90mm is a bit low on the front apron but it depends on the shocks & springs condition & whether or not its been lowered. Going to 19” wheels will give you 15-20mm depending on rubber but you might need new shocks. Mine -2005 are weeping fluid slightly but have lasted 19years!!. So if yours are original they need replacing anyway if they havent been touched before.
    • Hi everyone, Recently got handed down a 2004 Skyline 350GT Coupe. I would like to change the wheels as the previous owner installed some weird ones. The current ones are 215/45ZR18, unsure of the offset, and sit pretty deep in. Would like to increase the ground clearance slightly as well as I need to get it roadworthy standard, currently sitting at 90mm. Was thinking that maybe I could kill 2 birds with 1 stone by getting new wheels.  Pictures of current wheels: https://imgur.com/bg1QMIu Any recommendations for the types of wheels I should be on the lookout for? Like the maximum and minimum offset, sidewall height, width, etc.  Sorry in advance if I'm noob, I do not know much about cars other than how to change the oil, a blown tyre and brakepads....
    • Hey MinKer, Where abouts did you get that table from ?
