Help! R34 Gtr Mfd Error
cpark
 Share
Hi All,
I've recently picked up an r34 GTR and have had a few minor issues (it's more annoying than anything).
The MFD screen intermittently displays some sort of error message in Japanese which I cannot understand and was wondering if anyone on this forum has come across the same issue in the past or know of what the issue is?
See the below photo of the message. It seems to just come up at random times but there is also a constant beep (pause) followed by another 2 beeps every 5 minutes without fail everytime I have the car running.
I should also mention that the car came with the factory sat nav upgrade which is virtually useless here in oz.
If anyone could help that would be much appreciated.
Cheers
No I don't think so. One minute if be running the gauges on the mfd and then all of a sudden the message pops up when I haven't pressed anything.
I highly suspect that it has something to do with the factory sat nav unit.
None of the buttons on my factory sat nav unit do anything when I press them so don't know whether that unit itself is buggered.
The beeping noise comes on as soon as I start the car and then every 5 mins thereafter. Have no idea whether the sound and the error message is related.
Thanks
Thanks
Think what you want.
I can read all but one word.
You can assume what it is.
I would bet it is insert.
Anyway, whatever.
I don't care if you believe me or not I also don't care if you fix the problem.
  • Like 1
Sat nav disc is but maybe the disc or lens is dirty and can't read it.
Doesn't quite explain why none of the buttons work on the sat nav unit especially the tv button.
Anyway, whatever.
Mate I wasn't having a dig at you or saying you weren't on the right track I was merely explaining the rest of the story so that I could try and see whether there was any link between the issues or whether they were completely unrelated.
Anyway appreciate your help.
Insert program boot disc is what it is saying. That unit cannot read its internal memory.
Quick fix, pull the plug on that unit.
Proper fix, convert to 2 DIN radio.
The mfd gauges are separate to the navi.
Shame you aren't in brissy. I would like a crack at fixing one of these.
Thanks all, much appreciated.
I've tried taking the disc out previously and nothing really changed.
Will definitely be switching over to double din in the future but have a few other things if like to do beforehand so will probably go down the route of unplugging the sat nav unit temporarily until I get around to the permanent fix.
Cheers
  • 2 months later...
Regardless it's the initial interaction that will always give off the lasting stigma..have a look then PM me ohhh yeah... ;)
It's pretty hard to accurately gauge a person by what they wrote on a forum. No sarcasm, facial expressions etc...
Have a look then PM me? What?
  • 5 months later...
Hey mate, never really ended up finding out what the actual cause of this was but I ended up just pulling out my factory sat nav unit and it stopped the issue.
Not sure whether you get the beeping noises at every 5 min interval? This went away as we'll for me as soon as I got rid of the sat nav. Strange you are getting the this issue without he sat nav? I think from what the guy have translated above, something related to an error loading the disc?
Sorry I couldn't be of more help.
 Share
    • I think the pic in the first post is another car, and post 7 is OP's car with standard arms and swaybar swaybar swaybar. I can't tell what brand the silver coilovers are, and even if I could I don't know whether the spring rate is OK, if you can find a brand on the shocks and numbers on the springs that might help. Also, if you can measure the ride height from centre of your wheel to the guard that will help with advice too as handling suffers if ride height is too low
    • sadly, pics no work. that car must have spent a lot of time in a cryo bubble
    • In the first photo you posted, the colour of the control arms are the signature colour for Ikeya. Same for the swaybar, signature colour for Whiteline.  I like Hardrace, they also do hardened rubber bushes if your car is mainly a street car.  I like GKTech as well, but they use a lot of rose joints in their stuff so might not be the best choice for everyone.  The system might have been good back in its day, but it's a prehistoric system now. I suspect that most people have removed the HICAS as they want the car to do what they want to do, not what the car wants to do. From what I also understand, it isn't consistent in it's behaviour on track so it's hard to trust the car/know where its absolute limits are for track use.  Having said that, I think the HICAS eliminator kit was the first thing I installed when I bought my car. I don't personally have any experience with the HICAS system on a race track.
    • Thanks for the info. Didn’t know I had aftermarket control arms already? Will talk to my garage. What brand would u recommend if I want to play around with my camber more? I would think my camber is around stock level right now or more negative now due to lowering with coilovers. I will be lower her again 1.5 cm to get some more.    also why does everyone like to remove the hicas system? Is it because most don’t work properly anymore or ppl just don’t like them. Mine is functioning as it should be right now.    thanks for the good info
    • It looks like you've got Ikeya control arms and an aftermarket sway bar, maybe whiteline?  Or am I just going crazy? lol Unfortunately it won't, but what it will do is look really pretty. That's about all unfortunately.  How much neg camber do you currently have? Generally lowing the car dials in quite a bit of neg camber as it is. If you do go down this path, your best bet is get adjustable arms, toe arms (or preferably a good HICAS elimination kit) and traction rods. With all 3 being adjustable, you'll be able to dial out any bump steer that is introduced by playing with the camber settings.
