V36 Missing Hessitation?
30ONA
 Share
Hi All.
I have an 07 V36 (VQ35HR) and I think I have a very minor miss. When accelerating lightly usually uphill or hard acceleration I can feel an ever so slight sense that the power is not smooth and I can only describe this like a miss. There is still plenty of power but the delivery feels like it could be smoother. Before I go changing plugs ($100 for set of iridium's) could there be anything else to look at?
I have data scan but not really sure how to us it to identify this sort of issue (assuming there are no code issues).
Thanks.
Got the spark plugs and off I went to replace them. Even got a new socket to fit as is has a 14mm hex which is tiny. So started on the passenger side and could only remove one plug. The socket seemed to be slipping of the hex. I though maybe the socket was too thick so I ground down the outside of the socket thinking it was fouling on the outside of the plug hole. Still no luck. So I stopped and put it all back together again. I have only replace one plug and didn't bother on the driver side as I'm sure I will have the same problem. I didn't want to strip the spark plug, thinking I'll have to take it to the mechanic and spend $200 on labour unless someone here can help.
Is there a special tool for this job that only Nissan has? Has anyone had this problem before.
 Share
