R33 Gtr Spoiler - Help
R33-GTS
 Share
hey guys, i recently bought a pretty cheap r33 gtr spoiler, today i noticed that the brake light was sitting unevenly. so removed it to find that it was an led strip with a red lens rather than an actual nissan light. the red lens is made of some stupid thick plastic that looks terrible.
So i was wondering if anyone was selling a brake light
OR
recommend an alternative to try and make my own
thanks dudes
 Share
    • Superpro are fine. There are some applications (R32 FUCAs for example) where they are no damn good, but typically for any normal suspension bush, they are fine. Some people will complain of them making noise. Some people will complain of them collapsing. But many of those can probably be traced back to not properly lubing at install or other installation problems, or possibly other problems elsewhere in the suspension that put additional load into particular bush. And for the legit complaints? Meh. Deal with it. I had to replace the poly bushes in my R32 FUCAs every year. The real issue is that I am sold on the idea of adjustability of at least upper arms. So I only have spots for poly bushes in lower arms these days, as everything else is either hardened rubber or spherical steel.
    • Suspension really is complicated.... All these considerations are making me over think it all. Again. I reckon I'll wait for SK's response on his coilovers, and go from there. Though if I go MCA, I'll have to decide on whether the extra $600 (voston comforts $1890, mca pro comfort is $2490) is worth it. Just something soft and comfy, yet firm enough when required at the track or a casual old pac drive for a pie... Otherwise, anyone have experience with SuperPro bushings? Needing to replace the bushings on the suspension department... Will probably keep the oem uppercontrol arms etc, and just replace the bushings.
    • yes you are right, indeed it is for information only.  there is not much difference being at 9 or 9.5 or 10.  but when I see that you have to plane the block by 2mm if you have taken (example) CP piston which means that you end up with an 8.2 with the rb26 cylinder head.  hence the question I ask is what would be best to achieve what he is asking me.  take pistons in 9.0 or 10.0 to avoid planing a famous 2mm on the block knowing that I worked on the dome of the cylinder head which became total hemispherical
    • 600km?! That's amazing lol, was that turbo or non turbo? I'd be lucky to get 400km on a tank lol (though that's mods for you i guess lol)
