My Rx7 S8 Track Car Build
I always wanted an RX7, but was to expensive/impractical when I was 18. Skyline has done well, but part of me still wants an RX7.
Look forward to seeing how this goes :)
  • Like 1
Nice to meet you to Mick!!!
yeah I got caught in the act of buying all this.......... cos racecar!!!
and thought it might be an idea to buy a surge tank whilst I was getting other bits and pieces.
lets just say I'll be eating cardboard for the next few weeks!!!
hopefully have almost sorted out the boost issues will finish putting in the new solenoids tomorrow and test her out!!! :)
do it once do it right :)
2 ltr surge tank with the option to later fit another Bosch 044.
Because one isn't noisy enough!
Coming along well!
Any luck with the solenoids?
ended up replacing the whole blackbox of 7 solenoids and 2 green solenoids as one was brittle and broke and I now have pressure in the vacuum system!!! but I'm still not getting secondary boost so first point of call is to check I'm getting vacuum in the vacuum system (separate from the pressure side of the vacuum system)
The system is so complex its a challenge to get my head around it.
The turbo control solenoid uses both vacuum and pressure to operate properly, if not then it wont transition effectively. so I need to see if the "charge control actuator" and the "turbo control actuator" are moving then it means I have vacuum and the solenoid is faulty. The charge control solenoid was in the blackbox so that should be fine! so if that's working correctly I'll see the "double throttle control" actuator moving also.
so much to check and make sure its operating correctly but I'm happy I'm getting on top of it!!!
here are a couple of pic's to show the head f*ck LOL
  • Like 1
That's the thing Brett apparently a twin turbo FD with 280kw will blow any single turbo FD away even if it has 400+kw and some guys are pushing 345kw (537nm @ 5200rpm) out of the twins.
So if I get all the vacuum system and solenoids replaced which I'm over halfway already with fault finding then it'll be good for another 12-15years (and with a vented bonnet maybe longer as there isn't as much heat in the engine bay.)
You hear so many different stories and people are trying to push there own parts ETC but apparently all the FD race stuff ie: Spirit R or Bathurst R are the best items with the least problems but then some guys swear by the single turbo setups.
Its hard to know what's right or wrong so it comes down to personal preference I guess.
    • Did a little bit this afternoon and pulled the dump and turbo off so I could take the mani off to clean it up and give it a few coats of paint. Wire wheeled what I could get to and then got the sand paper out to get the tight spots. Gave it one coat so far, will do another two tomorrow and see if I can fit it in the oven to bake it for an hour along with the adapter and dbw.  Hoping the exhaust wrap I ordered turns up soon so I can wrap the dump and screamer. Ordered 30M so I'll wrap back as far as I can to help a little with temp next to the box and also the floorpan.
    • Yeah I think overall I’m running the expected power I should be running for now and I’ll just enjoy it for the time being until I get some other parts. Thanks for the advice mate I appreciate it!
    • That's fair enough.  Might be time to just enjoy what you have until you sort the ecu/flex sensor situation. You can pretty much guarantee that you are knock limited and e85 is going to be the solution to more power.
    • He didn’t provide that info to me but I think I’m on standard timing. And no we don’t have e85 on the petrol stations here but it’s widely available here from shops. I’m just planning on getting a better ecu before switching to e85
    • Seems bang on to me , g30-900 will make 900 crank on e85(on paper). Deduct ~25% for 98 and you are at 675 crank. Run that to the wheels and fact you are only running 26psi you end up about your number.  People forget how magic E85 is now that just about everyone is running it.   "Back in the day" you had to be north of 30psi on a 850+hp turbo to get 600 at the wheels on 98.
