R34 Gtr Tv Tuner/audio/navigation Unit - Boot Wiring Colour
You need to check that the earth ring near the ignitor is properly earthed to the head, from factory the ignitor and coil earth are part of the coil pack cover mounting, and you won't get spark unless it is properly earthed.
No the convertor needs to go onto the gearbox first
Thanks guys. Hopefully nothing is fooked up. The converter is meant to be bolted onto auto flywheel first hey? Not later. I like the hoist idea, I can do that at work. The tail shaft bolts are tight as fook and auto box is as greasy as fook. I guess ill need to put some wood between the sump and cross member to keep engine in position? Doesn't have any manual stuff. Same engine and gearbox. That were original. If the gearbox is busted i'll be looking for manual conversion.
Probably a little too far, but just in case, who/where do you have in mind?
It could also be the converter not all the way in
