Stereo Dropping Volume After Being Played At High Volumes
jackbh241
 Share
My M35 runs an aftermarket headunit direct to speakers and I've had this issue since I bought it years ago. Basically if I turn my music up loud it lasts a few minutes (sometimes a solid 15 minutes or so) but eventually all quality is dropped, volume decreases and gets fuzzy/low end gets cut etc.
I always thought it's probably just a faulty head unit but I've since replaced it and I have the exact same issue. Any thoughts on what it could be/how to fix it? I don't even know where to start?
It's just a standard head unit wired in (no amps, subs etc)
Any help would be greatly appreciated!
You are probably overdriving the output transistors and they are shutting down from overheating. If you want to play it that loud you may need an amp.
Hey Scotty, Thanks for the advice. I had thought the same so I went out and bought an amplifier but it did not solve the problem. It seemed to solve the problem for about two days and then right back into it the only difference is that now the volume/power comes in waves; ie it will drop off, then come back a few seconds later, then off again etc. In the past the volume cut until you skipped a track and then it would come back for a few seconds until it dropped off again.
The only change that I can think of that happened on the third day that it started failing again is that it was a cold morning so I used the heater, is that possibly related?
If any one has any advice it would be greatly appreciated!? we aren't even talking excessively loud volume here (just enough to be clearly audible with an open window) and it's an issue that I can never get to the bottom of.
So you definitly do not have Bose speakers? Just the normal Nissan stock ones?
Well I have never checked the labels on the speakers underneath the door cards but unless someone has previously changed the centre console all signs point to no. No sub in boot etc or anything either. Would it change the situation if they were the bose speakers?
Bose system has amps and also low impedance speakers. Driving them directly would give problems on several levels..
Might be worth fitting some quaility front speakers and disconnecting the rears. That should fix the issue, as well as sounding better... Assuming that the new head does not wierdly have caught the same problem as the old one...
Thanks for the tips. Well I swapped the head unit over but used the same wiring jack (it was the same brand so didn't require a rewire). However it doesn't make sense that it would be a short circuit to me because surely then it would be blowing fuses and it wouldn't matter what volume it's at, right? Is there something else in the wiring of the Stagea that could cause this?
in the c34 Prime as I have they use a common ground for the speakers , when I did mine I had to totally rewire the system to create independent speakers , maybe run some wires externally to see if it works before the rewire.
 Share
    • Nice work on the shroud/ducting.
    • Hi and best of luck with your car. Its a bit hard to tell how low the car is all round from that pic or if its been lowered or not. 90mm is a bit low on the front apron but it depends on the shocks & springs condition & whether or not its been lowered. Going to 19” wheels will give you 15-20mm depending on rubber but you might need new shocks. Mine -2005 are weeping fluid slightly but have lasted 19years!!. So if yours are original they need replacing anyway if they havent been touched before.
    • Hi everyone, Recently got handed down a 2004 Skyline 350GT Coupe. I would like to change the wheels as the previous owner installed some weird ones. The current ones are 215/45ZR18, unsure of the offset, and sit pretty deep in. Would like to increase the ground clearance slightly as well as I need to get it roadworthy standard, currently sitting at 90mm. Was thinking that maybe I could kill 2 birds with 1 stone by getting new wheels.  Pictures of current wheels: https://imgur.com/bg1QMIu Any recommendations for the types of wheels I should be on the lookout for? Like the maximum and minimum offset, sidewall height, width, etc.  Sorry in advance if I'm noob, I do not know much about cars other than how to change the oil, a blown tyre and brakepads....
    • Hey MinKer, Where abouts did you get that table from ?
    • Most likely your engine is toast, but also the R32 GTR has different ratios than the GTS4. In 5th it's basically the same, it's mostly 1st through 3rd that change. Stop trying to do WOT pulls before you make the engine entirely unsalvageable. Do a leakdown test and/or borescope the cylinders first. And a boost leak can overspeed a turbo. Make sure the turbo actually functions as intended.
