Streaking Wax
Hadouken
 Share
All you detailing gurus out there, I need some advice.
I am being plagued by streaking wax, only on my bonnet.
I have searched and searched and they say it's either contaminants on the paint or not letting the wax cure long enough.
Now It doesn't matter if I let it cure 30 min 1 hour 2 hour even went as far as leaving it for 4 hours. Nothing makes a difference to it streaking.
Today I clayed and polished the bonnet with RO. Used a brand New pad for waxing (thought maybe a old pad was causing my issues) alas nil change. I have tried multiple waxes and nothing changes.
I have tried every speed setting on my RO with no result.
The only way I am getting around it is by using a damp cloth afterwards and even then it is some elbow grease and repetition to remove it.
FML midnight purple.
Any advice?
What kind of wax are you using mate? I'm guessing a liquid based synthetic polymer? Are you using a fairly slow speed setting on your machine?
When you say streaking do you mean it is difficult to remove in some areas or do you mean once you buff it off you are noticing streaks our in the sun?
Sorry for all the questions just trying to narrow down the issue :)
I have tried every speed setting. Usually I go for a slower speed and do 2 overlapping passes.
It is easy to remove the film of wax. It is not the white residue I am speaking of.
Once the wax is removed you can see the darker streaks on the paint which can be manipulated by a cloth.
I have tried synthetic, carnauba hydrophobic polymers the lot
Maybe something leftover on the paint after polishing? Like polishing oils. Try IPA or wax/grease remover after polishing but before wax application. Or add a glaze in between. Personally i use Dodo Juice Lime Prime light after polishing to prep for wax
Edited by junkie
wax your car in the sun.
I apply with a megs applicator pad by hand.....or with my own bare hands.
that is the best way to applicate, I avoid machines for waxing.
I use the straight line technique to apply then buff off with a microfiber towel in circles.
I do not get streaks doing it this way.
Having read what you have said, it now sounds like maybe using to much product? Especially when using a good quality high carnauba content wax (such as Dodo Juice, Swissvax etc.) you only need very small amounts and personally I would always apply them by hand as opposed to a machine as you are not needing pressure and heat to help you. Always ensure the panels are cool and never do it in the sun with carnauba waxes. You can only get away with doing it in the sun with synthetic polymers but even then I still wouldn't do it as panel temps can get over 60 degrees.
If you can easily manipulate the streaks just use a few different soft microfiber cloths (using good quality MF cloths is especially important here as cheapies will make the job much harder) and keep gently wiping away until all the residue is gone.
But it does sound to me like maybe using to much product so maybe give that a go. Also another thing to think about is with a lot of waxes once they are cured and removed, they are hydroscopic for the first 12-24 hours so avoid getting the car wet and they may leave a slight haze during this period due to absorbing moisture from the air (an annoying issue for me in such a high humidity climate of NQ).
 Share
    • Yes indeed ; They offered it to me, I'm waiting for their quote 😉
    • Hey, thanks dude. Freedom to do whatever one wants to with their own car and build, but personally I don't want anything that's too precious. If I can't beat on it when I feel inspired, what's the point of having a car like this? And if I break something, it's me who's going to be fixing it myself...
    • https://files.fm/u/nrm9zrpkjj
    • Admin delete if not allowed please, I just purchased an r32 GTST with a Gtr front bar , grill I assume bonnet? (maybe) I have 2 questions he told me it had an RB25det I’m new to the RB world, and this is the photo I have taken and also I noticed a piece near my suspension broken is this fixable , will update new photos tomorrow once I have lifted her up and removed the LHS wheel I want to know if there is ways around this , I didn’t notice anything as it drove with no knocks on the suspension or weird feeling    the car feels sluggish, and the rpm cluster literally goes to 3.5-4k rpm and when you put your foot down it dances around like the local girl on Canterbury road or Sefton playhouse the car sat for 8 years he said the oil was dropped and re done , I noticed the oil was very clean car starts no problems by all means it’s not a clean car it is a project but doesn’t need much, knowing me I will go overboard the colour is horrible car has 88k kms hardly driven needs a few things but it’ll be fun to build properly    so guys is this an rb20 or rb25 and what is this bracket called? Can it be fixed thanks
    • found this on the forum , suggests I am in the range  ----------------------------- From the segmented (potentially incorrect) information I've found that;  Early R32: RB26000XXXX to RB26002XXXX  Mid R32: RB26003XXXX (V-Spec I RB26-03XXXXX - Reference Classic Register) Late R32: RB26004XXXX (V-Spec II RB26-042XXXX - RB26-045XXXX - Reference Classic Register) Early R33: RB26005XXXX Mid R33: RB26006XXXX (as per the engine in this R32 V-Spec II, which is what I'm concerned about from legitimacy perspective) Late R33:  RB26007XXXX Early R34 (2000+):  RB26008XXXX ----------------------
