Often Shudder At 110km/h
YangLIU
 Share
Was about to say the same as Ben ^..... try some rims that fit without the adapter
that means i need borrow set of nissan stock rims....
i just changed the position between front wheels and rear, let's see on Monday.
the hub adapters are brand new. I bought the hub adapters because the vibration problem, but the problem didn't get sorted.
In no way ever could hub adaptors fix a vibration.
  • Like 1
Or take it pedders for the steering and suspension check. Im pretty sure if you took it to the tire place and get them to look at it. Im sure when you explain it to them they will know whats wrong with it. Better then going back an forward on a forum arriving and no answer is it not.
So car drives fine.
Starts vibrating.
You buy hub adaptors.
Is that what happrned or something else inbetween?
So car drives fine.
Starts vibrating.
1. my car has vibration problem when i bought it
2. I did 4 wheels balance, and changed 4 brake rotors
3. bought new rims with previous tyres and balanced
4. bought hub adapters
5. just rotate the wheels between front and rear
still has the problem.
i record a video here, you can here some noise from 20s - 24s when I accelerate the car (around 50-70 km/h) and the ground is not smooth. this noise is from rear. I assume this is caused by same failure.
sure, I will do it when next maintenance.
  • 4 weeks later...
all sorted after changed 4 new tyres and tailshaft balance.
first I did tailshaft balance but my car still got vibration problem
then I went to MRC and they said my tyres are worn uneven. the vibration problem is gone after changed 4 new tyres
thanks all your help, mates.
  • Like 1
 Share
