Fs R33/34 Rb26 1000hp Ati Balancer
Up for sale is my ATI 1000hp balancer.
Condition is pretty much brand new as it was fitted to the engine once but was then removed as I'm going to a crank trigger set up. The engine has never been started.
Comes with everything that's with a brand new balancer inc water pump pulley, stickers and instructions.
Chasing 650 which is reasonable considering the price of Aus retailers and the cost of importing from the USA with the dollar the way it is.
Located Sydney and will post
0432528844
Cheers
Forgot to mention that the balancer comes with provisions for a dry sump mandrel
Do have pics on request
More info
ATI Super Damper Harmonic Crank Pulley for R33 and R34 RB26DETT. This truely balanced crank pulley was made to eliminate torsional crankshaft vibrations caused by abnormal wear. It is a direct replacement for the OEM crank pulley. Made to exceed SFI 18.1 Specs with laser engraved timing marks. The ATI Super Damper is also coated with black zinc chromate to prevent rust and reduce wear.
The Super Damper does not retain stock belt size. You will need to measure for the correct belt size.
Damper includes new aluminum water pump pulley for clearance. A/C belt is a 25% overdrive - DO NOT USE BELT IF RACING! 15% underdrive on power steering, OEM size on water pump.
Approximate weight of the pulley itself is about 11 lbs, good for 600-1000HP.
 Share
    • Oem std front sway and new oem end links mate   Rear recently moved to 24mm whiteline sway using the links that came with that
    • Hey mate just out of curiosity what front swaybar do you run and do still use the factory end links if you don't mind sharing that info.
    • They will be (within normal range) and they won't be causing the misfiring.
    • Chinese parts can be good, it's all in the quality assurance, and materials, but, that costs more, but, typically not alot more, it is up to the customer who is getting the parts made, some are happy to pay more for quality good QA and materials because the savings are in the cheap labour costs, so they can sell a quality product at a lower price point, other customers who are getting parts made give no farks and want their products to be as cheap as possible for maximum profit, so minimal QA and average materials  Hence why some Chinese parts are crap, whilst other are good Much like parts and other stuff made in different countries around the world, including "made in Australia", "made in Japan", "made in 'Merica" branded gear
    • Agree with Bogan bloke above. I like running quality tyres on my street driven cars. Wife's daily as well as my daily have Michelin PS4, good tyre that does everything you'd expect without fuss and reasonably priced for popular sizes that aren't enormous. Skyline had Yokohama on it for many years but have recently fitted zestino tyres. Just did a quick Google and they're actually Chinese made (jap designed apparently). Surprisingly they grip really well, wet and dry and haven't died, YET. Obviously on the higher end of CCP tyres but still China nonetheless.
