Setting Timing On 25det Neo
DaveB
 Share
Hi all,
How are people locking off their ignition advance to set base timing? I've got an inductive pickup timing light with the pickup clipped around the white wire loop at the start of the coil harness (it's at the back near the firewall), but the ECU is constantly varying the timing and it's very difficult to read. How have other people locked it at 15 degrees?
I have tried Conzult's "idle setting" but that doesn't tell me what the timing is set to, and it doesn't seem to be constant. It just seems to adjust the idle speed.
Cheers
DaveB
Thanks guys. I don't have a spare HT lead unfortunately. Also the tuners I have been to have said they use a loop wire? I'm going to email one and ask but hopefully it will work...
Well I tried timing from various points and comparing them to the #1 spark plug using an HT-driven timing light, and I can now say for sure that timing off the loop wires shows about 15 degrees more advance than using the #1 spark plug method. I took some pictures if people are interested but I hope this is enough.
Some weirdness I noticed, has anybody ever seen this? With TPS unplugged (thanks owen1r) I loosened all 3 bolts on the CAS sensor, and then rotated until I observed the same timing with the light that the ECU was commanding (in this case 12 degrees). That was fine. But then I would notice that as soon as I tightened just one of the bolts to even finger tight, the timing would change back to like 5 degrees?! The CAS was definitely not rotating, and it would have to rotate a significant amount to make that much difference to the timing. Does anybody know what could be going on there? This is my second CAS too since I replaced it a while ago.
thanks
David
Lots of timing lights (generally the less expensive ones) read double the actual timing from the loop at the back, so if you are seeing 30o you can probably read that as 15o
Interesting to know thanks Duncan. Do you have any suggestion for why it might be changing when I tighten the CAS? I'm a bit worried that the CAS is reading UNDER, and therefore I might have more timing than there should be.
Edited by DaveB
I don't think it's that simple and I wouldn't like to just guess.
If the gun is picking up the leading edge of the current in the loop wire, the amount of dwell is added to the timing reading. It might look like double, bit that's basically just a fluke. It should really pick up on the falling edge of the loop wire to be accurate.
I would still not trust it, a plug lead between coil and plug is best option.
  • Like 1
I compared both and I couldn't find any correlation.
With the inductive pickup timing light, off this wire:
...I measured about 22 degrees:
But with an older style timing light, that connects directly to the spark plug (it has a long spring which fitted into the coilpack), it read about 5 degrees!
  • Like 1
Do some maths. I'm sure it would be able to be calculated back to the dwell of the coil.
I seriously can't be bothered looking I to it further!
It's enough to know to not trust/use the loop, especially without checking it to a lead.
Sure. What I meant to say was, it doesn't look easy like 2 x the spark-measured value or something similar.
  • Like 1
 Share
    • I can believe it if you're getting air into the pickup. Cavitation is tremendously destructive for pumps.
    • I think the pic in the first post is another car, and post 7 is OP's car with standard arms and swaybar swaybar swaybar. I can't tell what brand the silver coilovers are, and even if I could I don't know whether the spring rate is OK, if you can find a brand on the shocks and numbers on the springs that might help. Also, if you can measure the ride height from centre of your wheel to the guard that will help with advice too as handling suffers if ride height is too low
    • sadly, pics no work. that car must have spent a lot of time in a cryo bubble
    • In the first photo you posted, the colour of the control arms are the signature colour for Ikeya. Same for the swaybar, signature colour for Whiteline.  I like Hardrace, they also do hardened rubber bushes if your car is mainly a street car.  I like GKTech as well, but they use a lot of rose joints in their stuff so might not be the best choice for everyone.  The system might have been good back in its day, but it's a prehistoric system now. I suspect that most people have removed the HICAS as they want the car to do what they want to do, not what the car wants to do. From what I also understand, it isn't consistent in it's behaviour on track so it's hard to trust the car/know where its absolute limits are for track use.  Having said that, I think the HICAS eliminator kit was the first thing I installed when I bought my car. I don't personally have any experience with the HICAS system on a race track.
    • Thanks for the info. Didn’t know I had aftermarket control arms already? Will talk to my garage. What brand would u recommend if I want to play around with my camber more? I would think my camber is around stock level right now or more negative now due to lowering with coilovers. I will be lower her again 1.5 cm to get some more.    also why does everyone like to remove the hicas system? Is it because most don’t work properly anymore or ppl just don’t like them. Mine is functioning as it should be right now.    thanks for the good info
