Need Help Please
Good day everyone, my name is Zaid I'm new to this sight. I'm hoping some will beable to assist me. I have a skyline r34, it has the rb25det neo motor, I have an issue that nobody can seem to solve, please can someone advise or give help. I'm from south africa and we don't get the skyline this side, so I had to import mine, so not many guys have experience in fixing this car. Firstly the car was stock.when I came upon this issue,the car would loose power like it dropped a valve, but it would only happen every now and again, I had it checked out I was told my spark plugs were wrong so I did research on sights got the right plugs and even gapped it to 0.8mm the car ran fine for awhile then the same issue returned about a month later, I then replaced the coils, thinking one or a few must be faulty , once again it worked for a month then the problem returned, some said my earthing of the car was not right. I sorted that out but the problem was still there, I then changed my injectors found out one was faulty. The car worked fine for about 3 months then the issue came back and shortly after that the piston melted and the conrod cracked through the block I replaces the motor and put a spitronics management system in now my engine light doesn't want to go off and the new motor is giving the same problem. I don't know how to fix this issue. Please some advice would be great. I'm not to clued up on some of the terms you guys use so please reply like you righting to a person that knows nothing about cars. Thanks in advance
  • 3 weeks later...
new motor, new coil packs, new ecu, new plugs, but same prob... maybe its somewhere in the fueling, fuel pump, fuel lines, fuel filter, or even the fuel itself.
If you have a buddy with a wideband, and if ur ecu (not familiar with spittronics) can do datalogs, this would be quite handy to help see what is actually happening when the power loss kicks in.
if you melted a piston i believe you could have a severe fueling issue or spark. and you covered alot on spark...
  • Like 2
Thanks Dev, I did reply a while ago but I.don't see my reply here, not sure why, anyway it's a stand alone management, it possibly could be fuel but if so, won't a dyno pick up that. I notice my spark plugs die very quick, sometimes only lasts 3 months if I replace them then the power returns. I'm out of town for awhile so.I won't beable to check.thoughs ideas at the moment, but I'll check on the fuel
if the car was dynotuned, then yeah definitely they should have picked up an fueling issue if it was lean or rich..but since you mentioned the problem comes and goes... perhaps that is why nothing was detected...
a bad fuel pump and/or fuel pressure regulator could make the car possibly run lean, maybe that was the case with the old motor melting the piston.
 Share
    • Did a little bit this afternoon and pulled the dump and turbo off so I could take the mani off to clean it up and give it a few coats of paint. Wire wheeled what I could get to and then got the sand paper out to get the tight spots. Gave it one coat so far, will do another two tomorrow and see if I can fit it in the oven to bake it for an hour along with the adapter and dbw.  Hoping the exhaust wrap I ordered turns up soon so I can wrap the dump and screamer. Ordered 30M so I'll wrap back as far as I can to help a little with temp next to the box and also the floorpan.
    • Yeah I think overall I’m running the expected power I should be running for now and I’ll just enjoy it for the time being until I get some other parts. Thanks for the advice mate I appreciate it!
    • That's fair enough.  Might be time to just enjoy what you have until you sort the ecu/flex sensor situation. You can pretty much guarantee that you are knock limited and e85 is going to be the solution to more power.
    • He didn’t provide that info to me but I think I’m on standard timing. And no we don’t have e85 on the petrol stations here but it’s widely available here from shops. I’m just planning on getting a better ecu before switching to e85
    • Seems bang on to me , g30-900 will make 900 crank on e85(on paper). Deduct ~25% for 98 and you are at 675 crank. Run that to the wheels and fact you are only running 26psi you end up about your number.  People forget how magic E85 is now that just about everyone is running it.   "Back in the day" you had to be north of 30psi on a 850+hp turbo to get 600 at the wheels on 98.
