Hey all,
Car is going into the workshop on Monday...
Turbo will be removed and sent down to GCG for my Highflow :D
Jaycar gear should be on the way very soon as well...
Highflow is costing me $1500 due to a slight sponsorship as well ;)
:D Muahahahaha :D
https://www.sau.com.au/forums/topic/103074-finally/
Aaaaaaaaaaaaaaaaaah no, just the turbo, stock tubo goes hard, and with my pfc I could really use the highflowed to it's full potiential, it'll be just a waste putting it back on yours...... :D jk
I wish I had the funds to highflow, will eventually :D That is the only thing really left to replace on my beast :D
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1894500
Yeah I dont have funds either.
Thats where parents come in :P
Dads giving me $1000 to get he rest of the stuff done etc.
HEEEELLLLLLO Long lost BROTHER! Can Daddy buy me a highflow as well thanks? :(
Great to see you have parents who are so supportive, and can afford to be!
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1894646
how did you manage the sponsorship? are you putting stickers on your car or something?
Yea basically. Just got in contact with them, things I was planning on attending etc. So yeah, in exchange for a sticker :(
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1894683
HEEEELLLLLLO Long lost BROTHER! Can Daddy buy me a highflow as well thanks? :P
Yeah well I basically paid for the whole car etc etc by myself. And now I need their help, so yeah, good folks :(
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1894691
Chris, are you taking your car to a workshop? Is it just the turbo you're removing and replacing at this stage?
I'd say do it yourself if you have the space, time and tools (or get your hands on a basic toolkit). Removing the turbo is pretty easy, and replacing it when you get it back isn't much harder, if at all...
There are some fiddly bits and some tight gaps, and a digital camera will come in handy if you think you'll forget where stuff goes, but it's all good and helps you learn. And if you don't have to pay someone to do it, as well as store the car in the mean time, then it's money in your pocket which can be later spent on more bits or further tuning... ;)
Or maybe, if you mean "workshop" as in dedicated area where you can do the work yourself, then you can just ignore me and carry on as above...
<_<
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1901266
There are some fiddly bits and some tight gaps, and a digital camera will come in handy if you think you'll forget where stuff goes, but it's all good and helps you learn.  And if you don't have to pay someone to do it, as well as store the car in the mean time, then it's money in your pocket which can be later spent on more bits or further tuning...  :D
<_<
Yep to an actuall workshop... Dont have enough time really to do it myself, and they will be installing the IEBC, DFA and a Mixture Display as well
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1902338
Geeze man, best of luck with it *envious*
What boost will you be running?
Are you going to fork out $150 for a Fuel Pressure Regulator?
Or injectors?
Youve got the exhaust(?), GTT 'cooler, & the new bits, all tuned together.
What power output are you expecting?
Id imagine with a FPR you'd be able to reach 180awkw at ~14psi fairly steadily.......
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1902832
Or injectors?
1. With the two settings, Probably 10 psi and 15psi
2. On the books Brendan :) Will come with time...
3. Yep, So Fuji Catback, IEBC, DFA, GTT Cooler, HKS Panel. I'm expecting once tuned to reach the 180awkw mark as you said. Then add the FPR, GTR Fuel Pump and a Split dump pipe.... Should reach the magic 200awkw. Which is where it shall stay :D
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1902990
how much are they charging you to install and calibrate the IEBC, DFA and mixture display?
(...mixture display, is that like an air / fuel ration gauge?)
https://www.sau.com.au/forums/topic/103074-finally/#findComment-1919358
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
