I've just bought myself an R33 GTSt, it loooks and feels great to drive (of course).
Unfortunately the one thing I didn't count on was how low the beast is. Having both lowered suspension and a GTR front bar means I have a barely roadworthy 10cm clearance at the front end of the car... Eeek, that's after driving a Holden Jackeroo 4WD for 2 years...
Basically normal driving is fine, but going into driveways gives me an aweful, big scary scrape, that almost drags off my soon to be repaired front bar. So I've given up going into driveways for the moment.
Does anyone have any tips for me?
-Max
https://www.sau.com.au/forums/topic/10460-car-too-low/
Drive reeeeeeally slowly. I scraped my front bar about 3 or 4 times good before I realised the speed you need to travel and the angles you need to go up driveways at.
You'll be over it in a months time. If not then it deffinetly is too low.
https://www.sau.com.au/forums/topic/10460-car-too-low/#findComment-167131
yeah, i have the same problem.. no matter how slow or careful some are just too steep and that doesn't even have to be massively steep too.. really carefully slowly and sideways.
Just don't go some places.. might have to stop and walk a bit :D Otherwise just budget every year for $300 respray and some fibreglass patching :P
https://www.sau.com.au/forums/topic/10460-car-too-low/#findComment-167161
Try applying some stuff to the underside of the front bar if you're that worried, just where you cant see it. Something like a few little pieces of black metal stuck on or something so that when u go up the driveway it just scrapes those.... just put them where u cant really see them...... just an idea.
https://www.sau.com.au/forums/topic/10460-car-too-low/#findComment-167303
I have same problem - just becareful is the only thing u can do - you will scrape it - you will crack your front spoiler from time to time ......... its just what happens to a lowered car the only way to get around it is hightening it and if u dont want to do that just use some TLC in even the slightest slopes and be prepared to do the occasional maintenance work on the front kit. It looks good but it is hard work keeping a lowered car also suspension wise it takes its toll a bit.
https://www.sau.com.au/forums/topic/10460-car-too-low/#findComment-167520
Thanks guys, I just didn't want to feel like the only person who it happens to. Basically the only driveway I can and will go up is the one at my house, (thank god), so I just have to park on the street elsewhere.
I'll just have it fixed and resprayed once a year or something, no problems.
-Max
https://www.sau.com.au/forums/topic/10460-car-too-low/#findComment-167819
If we have someone parked out the front of our house on the street (Live in a Cul-de-sac) my car is stuck up the driveway. Thats coz our next door neighbours lawn is in better condition then the local golf greens so if I got caught going over that he'd have my nads on a plate.
https://www.sau.com.au/forums/topic/10460-car-too-low/#findComment-168692
Originally posted by Nismo_Freak
10 cm clearance is alot... thats 4 inches nearly. My car rides about 2.5" off the ground. Of course stiffer suspension does make it a tad easier to go places cause the suspension doesnt travel very far.
2.5"!!! is that legal in Texas is it? Don't they have speed bumps or driveways there??? LOL
Interestingly enough, I checked and my exhaust sits a bit lower than my bar, yet it never scrapes, but I guess its because its closer to the wheels...
https://www.sau.com.au/forums/topic/10460-car-too-low/#findComment-168705
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
