has anyone on here used any other type of ems/ecu on their stag or does every one just autopilot toward an apexi unit?
some of the ems/ecu's in the hyperrev mags look like they would be a good replacement but i cant read japanese so dunno what would be involved?
anyone?????????
i am looking at maybe doin a complete computer swap if i could find a reasonably easily tuned (in australia) unit.
has anybody got any ideas?
  • Replies 52
Japs tend to use several tuning units but i think the most popular by far are the HKS F-Con V and Apexi PFC.
There are no good tuners for F-Cons in AUS so PFC's are the go really.
PFC's are full ECU replacement units, they are not piggy backs. You unplug the stock ecu, plug in the PFC, tune it and away you go. If you have a manual car, PFC's are just so easy to use, large availability of tuners and relativly cheap in the grand scheme of things.
Add to that the Sydneykid seal of approval and the use of a PFC by Brad in his spastic Rb26 Stag and that should be enough to seal the deal :)
There is 100% nothing to installing a PFC that is special. Its just that the base tune that comes with it isnt the best.
Heaps of people just put the PFC's in at home then drive easly to workshops to get them tuned.
I can see why they say "install and tune though" because really the install is nothing more than 3 bolts and 2 clips worth of work and it just makes sense to make it an entire package.
Must let us all know how your PFC install goes.
alex there are a few issues with the R34 powerfc that make it more complicated than simple plug and play. once the car is finished there will be some minor compromises and slight rewiring (hence the extra labour cost from UAS) however it will run the engine fine and as a sideline it seems that the ATESSA is not an issue. at least that is how it seems at this point.
we have run into some issues with other components so getting the car shaken down will take another week or so.
Hmmm, does anyone with FAST know if the plugs on the factory ECUs are available separately to the ECU unit itself, or are they listed as a complete unit?
And is anyone able to provide me with a copy of the FAST software, please?
thanks alex my rb26 is not spastic :thumbsup: i still havent installed the pfc yet, ive got all the wiring sorted but havent actually put it in as im still using the autronics smc at the moment, and ill be getting the initial power tune done with the Autronics for low boost and see how it goes.
i doubt the non-ecu plugs on the r34 harness will plug striaght into the non ecu plugs in the stagea which makes it fun to try and wire up (not to difficult with the wiring diagrams though)
Edited by CruiseLiner
which components are the issues with Andrew? and what are the compromises?
it plugs straight in as far as i know (so you don't need a new plug) but there is at least one pin which is taking a feed which is different to the R34 GT-t. i can't give you the exact pin/s but they spent some time trying to work around it.
at this point that is all i know but it seems that it will work and the next person that goes to them gets to reap the benefit.
  • 6 months later...
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
