  • Replies 64
Yeah i had the same problem.
Im going to find a cheap(er) twin second hand, osgiken or the like, and then use it until it needs a service then get it back to new. should buy me some time.
But at the end of the day i guess you look at your car and say i want x amount of power, what clutch is up to the task.
rob,
You have the same clutch plate as mine. They need to have a 'bedding in' period. I have no shudder at all, I can take off from idle in 2nd gear without kangaroo hop. You do have a very agressive 2500lb pressure plate tho, makes trying to slip the clutch a bit of an effort over stock.
The pressure plate is something you don't have to go othe top with and in return you get a very stock feel to your clutch, with great grab.
'bedding in' only takes a hundred k's or so. It involves slipping the clutch with a few more revs than normal and not giving it any boot fulls until its done.
If you give it heaps before hand it may take little 'chunks' of material out of the disc.
Yeah he is!!!! My skyline is going in on thursday.... I think Troy is putting his in early next week!!!!
Hehe Ross has soo many cars that he is starting to mix them up :D ... If I played my cards right I could have got Troys flywheel I reckon :)
grrrrrrrrrr
cheeky bugger
yeah mines in on tuesday, i could of done it this week but his install guys father died yesterday so to be on the safe side we went for next week.
$760 to install, my flywheel, 2500lb pressure plate and the 9 button purple clutch plate.
Good price Troy, I think SAU must be sending plenty of work his way, people blowing clutches left and right. Could you ask him if he has any plans to make twin-plate clutches, I think there would be a big demand for them, cause even the 2500lb clutches don't survive big power.
See'ya:burnout:
skyzerr33,
Are you sure you want the 2500lb pressure plate?I'm pretty sure He does a 2200lb which is significantly lighter. Even a 2000lb would be good.
The 2500lb is a leg breaker if you are not used to them. And it's quite a bit of overkill clamp wise.
I agree. I have the 2500pound pressure plate and the thing is a bitch to drive in peak hour traffic. You *have* to rev to about 1500-2000rpm and slide the clutch out (makes hill starts a pain too), otherwise you'll get shudder and the car will bunny hop along. I dont think rev gets this, he has the same 9 finger/puck clutch but a smaller pressure plate.
Originally posted by skyzerr33
grrrrrrrrrr
cheeky bugger
Don't worry.... I wouldn't do that to ya :(
He told me about the mechanic's father also. I fully understand why he won't be in this week but I am taking it to him this thursday still and he said a workshop two building's down can take the clutch out and put it back in and he can still do the clutch work himself. He seemed pretty confident that I would still receive the same worksmanship though. I didn't find out if it is going to cost any extra due to a third party though. I hope not as I only have just enough to do the clutch as is...
I'm pretty sure I am getting the same 9 button purple clutch plate as you too...
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
