I got a GTS-4, the powersteering rack has a fluid leak at the adjuster on the right hand side, what sort of seal does it use? O ring or ect, anyone know how to fix this?
Theres also some small lights on top of the guards and lights on the sides of the front bumper, are they connected or what?
thanks!
https://www.sau.com.au/forums/topic/11122-a-few-genral-questions/
Do you mean the reservoir has a leak? Or the rack itself? If it's the former, you can buy a bottle of stuff that will seal it up again from GP Auto 1. I had a VS Commodore before the Skyline, and the power steering pump was leaking like a SEIVE.
I put this stuff in and it fixed it up totally! I was only expecting a mild improvement, and the bottle even said that it wouldn't work on bad leaks. But it did, and I was amazed. My leak was so bad before that if I filled it up on Sunday, it would be half empty (on my garage floor) by Friday (which would be the usual next day I drove it). In the end I never topped it up more than halfway to keep the leaking to a minimum. But I could fill it up after I put this sealant stuff in.
I've got no idea of the mudguard lights, but the bumper lights sound like the factory option spotlights? If so there should be a switch for them.
