hi
i recently put an rb25 in my 32 and still have the rb20 computer in it the mechanic told me i need an aftermarket computer for it to run to its full potential and avoid stalling when stopping suddenly.
just wondering if the mechanic is talking crap and what computer would be the best for what i need.
thanks
benjis32
If your RB25 doesn't have VVT, then you can get the RB20 ECU re-programmed to suit.
Otherwise you will need something like a PFC, or Wolf make a plug'n'play unit for the R32. You can add in the wiring for the VVT stuff.
what is vvt and how do i find out if it has it
Well if your running bigger injectors you dont have a stock ECU
A stock ECU wont run bigger injectors.
Of course it will. All it's got to do is open and close the injector.
Problem is that the RB25 injector flows more fuel for the same opening time, so the engine is basically flooding.
VVT = Variable Valve Timing - look for a module on the front of the inlet cam, and a solenoid sticking out the side of the head (at the front).
there is a gold coloured thing with a plug on the end of it but there is nothing plugged in to it.
Im not sure if this is what you are talking about but it's at the front left of the motor and it is sticking out of the head.
Ok if the rb20 ecu has not been toch and just let to run the RB25 then you will have some serious overfueling brobs indeed.
With the vvt you could get a revs activated unit from Jaycar and use that to turn on/off the vvt when required and then just get the stock Rb20DET ecu remapped to suit the larger injecors of the RB25. (270cc Vs 370cc)
Also to note is it is rumoued that the water temp sensor for the rb25 is different to the rb20 sneor so this would not help the stock rb20 ecu run correctly either. I guess some of the boys using The nissan fast software would be able to confirm that.
Just food for thought man.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
