Hi,
Just bought myself a set of used Apexi Coilover, always a catch,
on the passenger rear side suspension, making squeaky noise, sound like something rubing against it, metal to metal.
its sound exactly like when u jump up and down on a springs bed (hope it describes better). made noise when driving or stand still and u push against it.
Does it means its on its way out?
3 of 4 shocks was fine, no noise.
problems after problems, feeeling so low.....
any one have any ideas?
thanks.
I *think* i have the same noise as you... almost like a scunching sound? except I have stock damper and spring setups, and it's on all four corners, the sound has only come out recently, and it's only heard when it's under a fair bit of load, like speed humps, coming in and out of my driveway (over a smooth curby type thing) and taking round abouts with a little bit of speed....
I can't tell any handling differences as such, at least from general lowspeed manouvering on the steet (apart from this noise of course)
does anybody know what this is?
the noise only come from 1 coilover, so i thought something is wrong.
performance wise, cant tell, but its quite annoying!!!
though mines squeaks on un even roads as well.
guess that is why its cheaper than NEW!!! ;p
tried to spray wd40? lol, onto the top rubbber mount, but NOPE, noise still there.
probly will try to swap to its original spring,
see if it goes away,
the previous owner reckon the Apexi spring is bit harsh for the road, so he replaced it with a softer springs for the rear.
Its not too bad, noise will go away if window is down. But am chasing for perfections!!!
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
