Hey everyone.
My mate daniel recently bought a turbo with the specs:
Front A/R .7
wheel 64.5mm
Rear A/R .82
wheel 60.5mm
t3 flange
It has garrett on the compressor cover, but no idea wat model.
He's planning on putting this on an r33 gtst.
He asked me how i thought it'd run. laggy or not etc.
So i figured. Why not ask.
If anyone could help me out that'd be much appreciate.
He is also upgrading the injectors, fuel pump, front mount, pod, exhaust, ecu etc.
Cheers.
https://www.sau.com.au/forums/topic/122834-turbo-queries/
Is there an ID plate on the cartridge at all?
Cartridge? not sure wat u mean.
dont think it has an id plate
just has garrett on the compressor cover
similar to pic below (THE TURBO IN THE PIC IS NOT THE SAME)
https://www.sau.com.au/forums/topic/122834-turbo-queries/#findComment-2268128
7 blade wheel, older t04 style wheels.
disco will know... where is he :P
the ID plate is near the centre, where the oil/water lines go in.
Should be a little plaque
I just called him and he said it had an 8 blade wheel
if that helps
https://www.sau.com.au/forums/topic/122834-turbo-queries/#findComment-2268209
Front A/R .7
wheel 64.5mm
Rear A/R .82
wheel 60.5mm
t3 flange
Any idea how this would run?
Rip the comp cover off and measure the major and minor
Makes life a little easier to track down exactly what comp wheel its running.
I'm assuming its external gate.
https://www.sau.com.au/forums/topic/122834-turbo-queries/#findComment-2268458
I cant really do that atm
cause its my mates turbo
Yes is external gate
https://www.sau.com.au/forums/topic/122834-turbo-queries/#findComment-2268498
