I can't believe the amount of s1 stags on here!
not that theres anything wrong with that, here's my s2 "prime edition" so i've been told, still stock standard at the moment apart from fmic, more to come soon
damn thats nice...... :D
I like the front bar
thanks, it's a stock front bar, i have only found 2 others with the same, i'm not going to change it, although wouldn't mind some skirts, does anyone know some brands you can buy in aus?
oh and here's another pic of a 34 gtr front conversion on an autech, what a sexy looking car!
Any one from here own or know who owns this stagea? http://www.carsales.com.au/used-cars/priva...te=All%20States
No idea who owns it.
Nice looking car, but a bit overpriced, even considering the work that's gone into it...
Not really, it would cost more than $20K to mod a standard one to the same spec's
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
