Hey guys, just having a bit of trouble with my R34 and getting it passed the blue slip here in NSW. It has the factory Xenon lights which were put back in after compliance. The place doesn't have a problem with this (they probably don't know what xenons are) but they have a problem because they can't turn the lights on, then off, then on again without the lights (usually only one) failing.
I was told that the Xenons have a delay timer so that you can't switch them on and off really fast etc and blow them.
If I turn the lights on, then off, then try turn them on again a few seconds later a buzzing noise can be heard under the bonnet from the lights, and either both won't come on, or just one won't come on. And it alternates between the two.. sometimes the right one comes on the and left doesn't, sometimes the left comes on and the right doesn't. I would've thought if they were on a delay thing it would affect them both equally?
I actually had a mobile auto electrician here to have a look at it but he didn't have any idea (fairly small town so imports and/or xenons are pretty rare here)
Everytime I turn them off and leave them for 30secs then try them again they seem to work.. I wonder if I can convince the workshop that it's a factory feature (if that's the case)
Thanks in advance.
https://www.sau.com.au/forums/topic/124863-r34-xenon-lights-delay/
There is something wrong with your lights or the light switch, xenons shuld go on as soon as you turn them on but they take a few seconds to become bright the first time you swich them on.
NOooo. Xenons are hurt by being turned on and off!
So yes funny things will happen - the xenon gas might even turn pink etc while it goes "ouuuch why are you charging me again!?!?". The buzzing is the ballasts charging them up to warm em up.
So .. the short of it is that it's a normal feature of HIDs and you shouldn't do it >_<
But when the buzzing sound occurs, the light it happens on won't even light up, no matter how long I wait. And if it was a normal feature wouldn't it prevent both lights from lighting up, not just one?
I know what you mean about the pink, when I first turn them on it takes like a second for them to become fully bright...
A place I took it to today said it had something to do with the Xenon module and that they'd have to take the front bar off to get to it etc etc... I think it's amounting to a rather expensive little expedition.
Took it into another place today and they say the lights are totally stuffed. Something to do with the ignition module and i'll have to get new ones from japan. Anyone have any idea how much that'll cost me?
Or even a cheaper alternative just to get some working lights so I can pass blueslip. I know they are meant to take out the xenon lights when R34s get complianced so what do they put in instead?
Edited by Lithius
Which part is the switch? The story is now that the ballasts on both sides are stuffed so I've ordered 2 replacement ones. They are fairly confident that that should fix it. Strange tho that both sides are f**ked and not just one.
The combo switch on the side of the steering . The contacts inside could be stuffed or a little plastic broken so the contact is not always 100% so your lights are playing up.
Yep that's the option i've gone for... the parts arrived today but couldn't get it into the auto electrician till monday so won't know until then if it's gonna work or not. Fingers crossed. Got the parts from importdriver.com.au they were pretty helpful.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
