1996 R33 Gts-t
Hey Guys
I Just got my tuned and dynoed
Dyno Graph Attached
No Mods to talk about
Turbosmart Boost Valve
K&N Pod
3" cat back which need front pipe change to the cat
what would you guys think i would need interms of mods
to hit 200rwkw or 220rwkw
cheers :laugh::D:whistling:
ok...i just had a big nite out - so i think i talk more sense now than when im normal....hmmm
anyway id suggest turning ur cat back into a turbo back. ask BATMBL about his s/steel split dump/front pipe and large cat - he might have a group buy soon. Next id probably go front mount intercooler. Those along with ur k&n pod will have a significant increase in power. Change ur K&N to an Apex-i pod - that will be a better one to use.
you are probably looking at a power of about 170 rwkws. Add to that an after market ecu (i know nothing about these yet - im doing my research still) u should be nearing the 190rwkws - but i believe when u get one of these u need a tune up. To hit the 200+ rwkws u can boost ur turbo a bit - but this will probably shorten the life of the turbo.
But please take this in - with that power increase, you are looking at a pretty god damn fast car. Drive it carefully. Make the necessary adjustments to ensure that there is plenty of grip and dont do anything rash on the roads.
Lastly - this is what i have read, i dont know if those figures are exact - the other more experienced guys can verify if i am correct or not.
Edit: max turbo boost i believe is 15psi. I am gonna leave mine stock, but looking to invest in an Apex-i pod, FMIC by the end of this year.
Edited by emsta2003
a comment from the side bench. max power is simply that, a given power figure at any one point. too many see this as the most important part. average power makes a car fast not peak power. you should focus more on average power. a stand alone ecu tuned correctly will win hands down over a piggyback in a comprmise tune.
Hey Guys
Dyno Graph Attached
K&N Pod
cheers :):D:(
i got 221.7 rwkw, i have exhaust, fmic, k&n pod, boost contr, 12.5 psi.
i got 169 rwkw before fmic, pod filter, and boost controler were installed.
so i got a pretty decent gain from my mods. i was happy indeed. the car is a 94r33 gtst
rob
50kws from a fmic, pod filter and boost controller is a fair bit :(
rob
rob
you must have got the same guy that dyno'd my car....throw that printout in the bin and get someone competent to do it...there's no way your car made anywhere near that figure with those mods :)
220rwkw is just a little far fetched... to the tune of about 30-40rwkw
Anyways, nezsaz - What is your budget. You need to set a $$$ figure that you have to spend then see what parts do and dont fit into your aim
That boost looks like it drops off pretty hard!
Is that Turbosmart "boost valve" a bleed system? If so, change it for a ball and spring type that you can buy in another thread around here.
my mods -
PowerFC
FMIC
Full Exhaust
Tune = 210rwkw.
Anyone that says you can make over 150rwkw WITHOUT an aftermarket fuel controller or ecu, is full of shit.
thats a bit low....with full exhaust, a fmic and some boost (10ish psi) you'd be over 150rwkw without any drama....ill go out on a limb and say that full 3" exhaust on a healthy 33 GTS-T will be 150+rwkw
I am trying to spend around anothe $2000-$4000 but not at once
i am still a uni student soo when i save up a bit i do bit of a mod
i am not in a hurry to get to the 200rwkw mark i think i will be
happy when i get there since after the tune even though it was
about 30kw different in power i def felt the difference soo i think
that 60kw i am after would be good enough for every day rd car
given the car already is a hand full in wet weather heheeh i am in melbourne
soo as you know weather wise we never know!!!!!!
if you want 190-200rwkw
you'll need
full 3" turbo back exhaust
front mount (or decent side mount)
s-afc or full stand alone ECU
boost controller of some sort
a mate of mine on here has those mods (s-afc) and a gtr fuel pump, and just got it tuned at 192rwkw .
the $2k-$4k will easily cover stage 1 mods! That being - full exhaust, pod, FMIC, ecu (with tune) and boost controller. (i think thats all isnt there?)
Do the basics first. E.g I have just put on the exhaust, next is pod and FMIC - should get me some good power gain. Do them first, then get the ecu etc. thats my opinion though.
255's or 265's at the back too :P (that is on top of the other mods that i listed)
my mods -
PowerFC
FMIC
Full Exhaust
Tune = 210rwkw.
Hmmmm, i wouldn't go that far.
I got 190 with FMIC, boost to 12 (bleeder), full zorst, pod filter.
...then got the Power FC installed/tuned.
went to 194 but the whole midrange thing is fantastic !
Yeah so did mine, but as soon as i got the result i didnt get excited because i knew it was inflated. So i went to a different dyno to find the truth.
I recon you guys should do the same.
lol so the 1 that said it was over 150rwkw was wrong, and the 1 that said it was under was right...
interesting theory, given the fact that a 187kw engine in the R33's would put them out at around the 140rwkw area stock....but yeah, definitely impossible to make over 150rwkw without fuel management
:P
:P
Yeah they might have come out with 187kw at the fly, but that was 13 years ago man. Alot can happen to a 13yr old engine..
I knew for a fact that the dyno i first had it ran at is happy because all of my mates have had theirs run on it, and they've all been run at other dynos and consistently scored 10kw+ lower then the original figure.
Let those 220kw+ skylines with just a FMIC and boost controller line up against a skyline with a proven 220kw and we'll see what happens.
 Share
    • well, to check fuel pressure all you need is a gauge and a 8mm joiner with a gauge port in the inlet fuel line; if it stalls at idle when hot you can open the bonnet and check pressure at that time; the fuel pump is a potential cause for what you are describing but it could also be wiring to the pump getting hot. You haven't mentioned that the factory fuel flow control on the fuel pump earth is removed. So either way, it is worth running a suitably sized and fused wire from the battery to pin 30 in a new relay in the boot.  Use the ECU trigger wire into the standard fuel relay to pin 86. Earth relay pin 85 and the Fuel Pump negative (nice big wire for the latter too). Run relay pin 86 pin to Fuel Pump +. That will remove multiple possible fuel pump wiring issues in a 30+ year old car
    • I've been running a 525 for years with the standard hat and FPR in the stagea (mine has a 32 gtr fuel rail and stagea and 32 hat and tank setup are the same) without an issue with base fuel pressure. You said when you disconnected the return it is OK, did you do so at the fuel rail or the fuel hat? Either way I'd be looking for blockages or in the case of the tank kinks in the lines downstream Note I did however have an issue with the current required for the 460 melting the fuel hat.
    • I'm trying to maintain stock appearance . Hicas is still installed (although has lockout kit) did you retain factory fuel pump hat? If so I assume you used a bulkhead fitting or similar ?  I was also trying to avoid a full re design as it was previously dynoed at 426kw atw with same setup but different pump. Changing return line would also mean having to change ethanol sensor and fpr and possibly fuel rail. Not chasing more power in any way just reliability of the setup
    • I do think it's weird I had it for 2 weeks then the issue came up out of nowhere and progressively got worse. I would've imagined changing everything in the ignition system would've resolved any ignition related misfires but still has the high rpm and idle misfires that seem unchanged. I would've thought if it was fuel related it would happen all the time unless it's the pump losing pressure when it gets hot. If it was the ecu I would think it would do it all of the time.  Something I noticed when I had it all apart was a pretty decent coating of oil in the J pipe coming from the throttle body. The weird thing about that is the pcv that goes to the intake is blocked off. So that has me wondering if the oil is coming from the turbo because that's the only thing that could get oil in there. This thing does sound like it spools like a mofo like I'm a former dsm guy and the only stock turbo I've ever heard spool this loud (to only go up to about 5psi) is on a diesel truck. And the recirculated bov is really loud too I had a TurboXS RFL and this thing is just as loud and being so low on psi seems a little weird. I don't know if any of this is or isn't related but just trying to make sure I'm not leaving any potentially helpful information out.
    • So latest update. I replaced the ignitor with a jspec unit from enjuku. It felt a lot better at first although it is a little bit cooler of a day than it has been. Warming up didn't have as much misfire sputtering as before. Went on a 10m test drive. Felt good, a lot stronger though I was taking it easy on the boost. On the return trip started getting the cutting out at higher rpm again and was getting worse the longer I was driving. Took it easy the rest of the way home. Before turning the car off was getting the normal idle sputtering I was getting before.  So where I'm at now, entire ignition system has been replaced with upgraded components. Plugs still gapped at .8mm. Removed the fuel cap in case it was building too much reverse pressure I'm the tank, didn't help at all. Now I'm still on the same tank of gas the fuel treatment was in, I'm thinking if I can run that out and then refill with fresh 93 maybe  the treatment is too concentrated in some areas but doesn't explain that it only does it once the car is warm. I'm leaning towards fuel pump or injectors but if the injector was clogging I don't think it would make it shut off like it has but then fire right back up like nothing happened. So my current guess would be the pump. Without a fuel pressure guage no way to test or check it while it's running.  So that's kind of where I'm at. Need to start testing fuel components and ecu/wiring but I'm at a loss of what's the next logical step and procedure for testing it.
