Dark26
Posted Yesterday, 06:48 PM
Don't think I can run that through FAST. It should be the chassis number like BNR32 and then 6 numbers. What car is this from? Can you look on any of the plates on the firewall for it?
HR31-057324
:rolleyes:
Edited by dw13098
Chassis number: KBNR32RXFSLMZG
Build date: 12/1990
Colour: KH2 = Gun Grey Metallic
This is a regular GTR, being that it is a 1990 model and there is an X in the chassis number. Not too sure what LMZG means. I did some googling but came up with different results.
Can someone run this one - BNR32-310633
Thanks in advance.
Model: KBNR32RXFS7NAA
Year: 06/1994
Colour: 732 = Black pearl
Regular R32 GTR. The N before AA could be SRS airbag, but I'm not too sure if this guide I'm reading is correct or if I'm reading it correctly.
HR31-057324
:rolleyes:
HR31-057324
HR31-057324
Can anyone see if this works on their FASTED
HR31-057324
please please please!!!!
Complications in your VIN, it cannot narrow down a specific build date...
Give us some more info like what engine it has in it?
Auto or Manual?
Thanks.
thanks mate, just wondering do you know what spec code SPOI6 refers to, I know that the TELV2 = the multi AV system with TV and possibly addvest sound system option.
Cheers
Hey man!
SPOI6 = No air spoiler... :blink::)
Could mean the car didn't come with a roof spoiler..?
BNR32-220432 Appears to be a '92 GTR in TH1 blue. Otherwise stock expect for susp and nismo control arms.
What can you tell me? RB26 timing cover has a riveted plaque that reads "Nismo" (engraved), then "Tuned by Nismo Omori Factory" Serial No. E012 (engraved)
What can you tell from VIN?
The VIN matches your description.
Check ECU and Turbo Part numbers to confirm if been modified by Nismo.
Post pics or send to me and I can have a look, thanks.
Bncr33022986 suppose to be BCNR33022986, "N" and "C" other way round :)
Thanks
A R33 GTR V-Spec in Champion Blue, is your GTR a LeMans Edition?
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
