Not sure tbh previous owner did it. If you want I can take a close up and you can try working it out ?
Yeah that would be good. don't know if it would help me haha but I'd like to see.
Chris, there was a thread regarding the clear indicators sometime ago...
I think it's either, pull apart another set and use the lenses or someone was getting clear lenses made by a pro. :unsure:
I'll try to find it for you. ;)
Does look good.
But 4door fogs FTW!!!
Edit* This is a start.---->> http://www.skylinesaustralia.com/forums/topic/334988-creating-proper-series-2-clear-glass-indicators/page-1
  • Like 1
how do the tinted ones look when in use?
Fine, I was sceptical at first. But the big orange dots are still big orange dots during the day when in use :) Driving lights im not too worried about as I've been booked for using them and never turn them on now anyways. But they do have a cool green tinge to them now when on.
  • Like 1
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
