Hi all , am learning about RB25DET differences because I like to take advantage of factory upgrade engineering when possible .
It was said that compared to the R33 version the R43 Neo engine uses larger exhaust valves , solid buckets and different chamber and piston crown design . If the chamber is shallower I guess the piston dish must be deeper meaning Nissan could have been looking for better anti detonation qualities and no doubt lower emissions .
If these engines use RB26 type con rods then that would also mean larger gudgeon pins wouldn't it ?
I'm beginning to wonder what needs to be changed to fit the Neo engine to an R33 electrically speaking . To have the late VCT working properly would mean the R34 loom and obviously the ECU .
Has anyone been down this road ?
And no don't want an R34 Skyline .
Cheers A .
https://www.sau.com.au/forums/topic/131861-rb25det-variants/
i heard they have hydraulic lifters, and the valve springs are considerably weaker then normal r33 rb25 and they suffer from valve float quite easily. That came from a workshop....so i dont know how much truth is in it.
Go the neo! Im not bein biased but i had a r33 series one engine in my old r32 it wasnt as smooth as the neo and wasnt as torquey. :) I got 170 kw atw on 12 psi front mount, exhaust etc etc. The neo has all the same mods and puts out more on standard boost. :)
They are still rb25 det they came out in the r34gtt. The head is different, throttle body they have a different cover on the engine, solid lifters,stronger rods,different pistons,bigger exhaust housing on turbo. Keeps its legs all the way to redline! Not like the old ones they run out of puff bout 5800rpm! And they make 19kws and 50nm of torque more than the r33 rb25...
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
