oh my god, stop clogging this useful thread up with crap. i was being facetious.
here's a few facts:
toyota and whipple are two different companies, and their blowers are COMPLETELY different.
currently i have an SC-14 on my RB30. i know what they are, and i know that supercharging has been covered because i did it.
whipple blowers are produced by lysholm AB industries in sweden. this is what is going onto my 25/30 hybrid engine. they are capable of massive power outputs with huge top-end airflow and no lag.
so stop posting useless stuff you obviously have no clue about. "toyota whipple blower" eh? where can i get one?
Stocky, you can't just not feed the vct from an external block source because it also feeds the front cam seal as well.
If you don't hook the vct gallery up the cam and seal will be rooted very quickly.
Also dont forget the front water gallery near the vct oil feed hole on the head surface needs some material added to it for a good seal. When you are getting the head reco, get them to weld the gallery up so it seals good.
And because you need that welded you might as well get the old vct gallery welded as well, rather then using a grub screw/plug.
ah okay i was under the impression that it could be simply welded up and re-faced, obviously not! so i HAVE to feed oil into that gallery somehow then? i might as well use the VCT then, it will be just as easy. i think i can set up an RPM trigger to feed 12V to the solenoid when it needs it, shouldn't be too hard. or i can just leave it unplugged.
so you're 100% sure i have to feed oil up to that gallery? i am sure i have heard of a few people just blocking it off with a grub screw and leaving it, that's all.
The grub screw you've heard about blocks off the hole at the head/cylinder interface as there is no matching oil supply hole in the rb30 block as in the rb25. If you dont block it off your external oil feed will leak through this hole.
I played around with disconnecting the VCT solenoid on my stock cammed RB30DET and found that without it the bottom end was noticeably doughy. It is a relatively minor mod compared to implementing a blower system...
I used to own a sc14 blower (not on an RB that's wrong) The bearings went in it coz I pushed it past 11psi.
Have you had the internals ceramic coated? coz going past 11psi with these things generate so much heat they melt the teflon coated internals.
Please read the previous 93 pages, you have not mentioned about this but others have. It's worth reading everypage and saves the frustration of having to explain it all over again.
my target is 350-400 ponies at the wheels (300kw or so) and i simply don't need any more than that. from all my calcs, i am pretty sure i'll only need about 14-15 psi at the most to achieve this (not from a turbo) so i should be right with stock cams etc.
I know who you are and I know you mean well but 400rwhp is asking too much from that blower that's suited to a 2L.
Have a look at the link for a larger version of this blower. http://www.oguraclutch.co.jp/english/e_pro...sc/sc_siyou.htm
Sure, you can up the psi but doubt it's guna last you long.
PS: read the last 93 pages, you'll get a better idea then. :)
Keep the insults etc.. out this thread it's not needed here. :(
PS: read 4 posts up and stop making a fool of yourself. telling me to read 93 pages of material and then, yourself, not even reading my posts before advising me on what to do is a little silly, no?
yep i understand all of this no problems, just don't know how other people got away with not supplying oil at all to the forward cam seal and gallery there. because i have definately heard/seen pics of RB30DET's with the VCT oil feed welded up, and no external supply at all to the oil seal.
any ideas?
You still don't quite understand. The blower used on the toyotas are whipple style blower. If you havent pulled both apart then trying doing that before replying.
If you cannot comprehend i'll show you the blowers in person.
Ps: You could put the motor into a better car tho.
they are in no way similar to a whipple blower at all, the whipple uses two counter-rotating screws which compress the air charge axially as they rotate. this is why it's called a twin-screw lysholm type blower.
the toyota blowers have two counter-rotating vanes which take a gulp of air and blow it out the other side. this is characteristic of a roots blower.
they are absolutely not the same in any way, shape or form. their only similarity is that they are both superchargers of some description.
whipple: compressor_cutaway.jpg
i don't have any inside shots of my SC-14 but perhaps you could post some up and understand just how different the two really are. apart from the casings looking vaguely similar, they are completely different. don't try and argue that a roots type blower is the same "style" as a twin screw because that's just stupid.
anyway back to the 25/30 thread here, is there any possibility of modifying the block to have another oil supply to the forward VCT gallery and using an RB25 head gasket? perhaps by drilling a hole into the nearest oil supply line and re-routing a portion of the flow to the new hole leading to the VCT gallery?
Perhaps we should move the supercharger posts to a new thread, this thread is really about RB30DET's. :)
PS, You don't get something for nothing, whipples need a lot of power to drive them (30 kw is not unusual) and they heat the inlet air charge up a lot (100 degrees C is also not unusual). This is a lot more power loss and heat generation than other designs. As I said, you don't get something for nothing, you have to pay the toll somewhere.
ah good to see someone took that flow chart i posted on board at least, yeah 40-50 horsepower to drive it at peak power, and they do generate heat, but then again i've seen some turbo flow charts with similar discharge temps. the gain is in the lack of lag, i'm just keen to try something new that's all. hate driving laggy cars on the street that's all.
but i digress, can anyone answer my questions above regarding the block modding or front cam oil seal?
I have answered this question so many times in this thread. Test it yourself, block off the VVT oil feed (on the bottom of the cylinder head) with a finger. Then supply compressed air to the oil feed hole at the #1 camshaft bearing. You will find that the air circulates around the oil supply holes to the other camshaft bearings, ie; they are all joined up. You only need the EXTRA oil feed for the VVT becuase it needs a good supply of oil pressure. The #1 bearing oil supply is the bleed off, otherwise the oil pressure would be trapped there and the VVT wouldn't turn off when the solenoid is closed.:)
PS, a correctly sized tutbo should NOT go over 70 degrees C air inlet temp, but a correctly sized whipple will ALWAYS have to go over 100 degrees C to make its target power. As for no lag, it depends on your interpretion of LAG. The problem with a whipple (and all superchargers for that matter) is that they require increased rpm to supply increased air flow. So they have to be accelerated by the engine before the engine can accelerate the car. This means slowed response to throttle changes, both accelerate and decelerate. Propelry sized wastegates and BOV's have meant that turbochargers don't lag (sorry) behind as much as they used to.
hmm two contradictory opinions, but it seems like you've done this a number of times. when i get the head next week hopefully i'll give it a go, come to my own conclusion.
and just a quickie, i have two options that i know of in terms of cam belt idlers/tensioners etc. do you suggest using the option of drilling a new idler stud hole up the top of the block or using two tensioners down the bottom near the crank pulley? the only advantage i can see of the former is less belt length on the slack side of the belt so perhaps less capability of belt whip/flop.
p.s. turbo vs supercharger, each to their own i guess. when it's running i'll let you know how it goes. hopefully the answer to that is "quickly".
I ALWAYS use the high mounted belt tensioner. In my opinion the low mounting position brings the belt too close together, the teeth are facing each other with sometimes less than 8 mm of separation. A little slack and you would have teeth to teeth contact at 6,000 rpm, and that does not make me feel very comfortable.
:rant:
Couldn't agree more, i looked at this in great detail when i built my motor, if you use the relocated tensioner the belt won't catch like it could do if you use the factory stud locations (which are way to close for this app) and with the relocated tensioner it also wraps the belt around the pullies better for more grip. :(
Gary,
don't stock rb26's let alone the os giken 3 litre kit use the lower tensioner and pulley setup? Meaning the belt has similar teeth clearance?
:rant:
no problem, it looks a lot better to me as well, for all the reasons you mentioned above.
two more questions then:
1) can you do it by eye with a hand drill?
2) how deep do you drill the hole to avoid going into the water gallery?
I made up a rig and clamped it to the block to help guide the drill bit completely square to the front block surface.
It must be absolutely right!
Then tapping it you have to constantly check with a 90deg square to make sure the thread is square with the front of the block surface.
I had an old block i practiced on first.
If its not absolutely correct the tensioner will sit on an angle andwear the belt and bearing, it may also not have enough grip if the trnsioner doesnt sit flush against the surface and may slip in use.
Someone may have a better idea but thats how i done it.
Because i had a spare block i was able to test the water gallery depth so to speak.
Its less than 9mm thats for sure, i had to cut the thread on the stud so it bottoms out.
I done it this way, but i really don't know if use would have trouble even if you went into the gallery and just used thread sealant on it, atleast that way the stud would have more thread/grip??
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
