from memory it depends which power steering pump you are using, and if the belts line up correctly. Assuming the alternator/water pump belts are the same.
but for the price of the ross units why not just get one of them?
Agreed!
its a standard rebuild that im doing so i dont need the ross
I was going to use my r32 one but for the price i might as well get a new one. I remember sk posting that he uses mostly rb26, i think ill have to do some old fashioned belt checking and see if i can do the same. Otherwise im sure the rb20 one will be fine
Actually cubes will know, where are you old mate?
Edited by Gts30t
  • 3 weeks later...
hey all,
slightly off topic but im in n.z and i have a spare r32 non vct rb25de head that im thinking about selling, just wondering how much should i sell it for?
i have had it vacuum tested,crack/pressure tested and have had the valves all checked and have had it dipped to clean it all up. Only thing wrong is the exhaust valve guides have a tiny bit of play in it. The head is disassembled also but everything is there to put it back together i.e springs,valves,camshaft,gears etc.
I also have a r33 vct head that im thinking about selling what sort of price could i get for that? would it differ compared to the r32 as the r32 head are harder to find?
They both (with manifolds) go for around 1k these days.
The R32 rb25de heads can sometimes fetch a little more due to the no fuss bolt on and go.
The r32 rb25de has 'slightly' smaller but rounder ports compared to the rb25det vct head. Regardless they don't appear to give anything away in the power making vs boost side of things.
Only real issue is both heads are hydraulic of which limits total power output (400rwkw max) on pump fuel due to the inability to run cams with decent lift 10-11mm.
i only have manifolds for one of them which im using for myself. how much do you think i could get just for the single head which is unassembled? A guy has offered me 450 in bits for the r32 head?
Correct but the tomei solder lifter kit requires a cam with a smaller base circle. So extension shimming would be required.
There is a mob I have the number for that apparently converts the hydraulic lifters to solids. Have yet to contact him to find out the details cost etc.
I'd personally machine the heads buckets, grab the tomei solid lifter kit, suitable springs, reco the head and then have Tighe cams grind up a set of billets with 11mm lift or so.
Yeah the only reason i ask is because its a good upgrade for a RB20 i heard and i have a RB20 atm and having the 30 being build (well getting parts together) and just thought i could put them in my RB20 for a upgrade while i wait for the 30 then put them into the 30.
But if i have to machine the 20 head then the 25DE head then theres not that much point as i dont want to do much to the 20.
lol bad boy bubba.. I love cats.. I wouldn't wrap one in gladwrap :kiss:
I looked into solid lifter conversion with some big cams and it came to about $2500 in just parts, then gotta add machining and downtime to that!
I'll stick with my stock NA cams for now..
JHH Engineering in qld does the solid lifter conversion for roughly $450, then add $1250 for cams & gears.
I just picked up a big head from them for a friends car im building (26/30 in a 33gtr), labour on the head was $3130 ($6k head in total)
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
