Ok.
Currently have:
PFC + 10psi + R34SMIC + 3" turbo back exhaust (not split dump)
This with a tune gave me 172rwkw with a nice smooth power delivery. (dyno is meant to be conservative also)
I have sourced a GCG high flow turbo. I'm thinking that 220-230rwkw will be adequate for me.
I'm wanting to hold a fairly tight budget.
I have a nissan patrol clutch - hopefully that will hold up.
So extra mods to reach the 220-230rwkw??
1. FMIC - Hopefully the same sided entry type, to allow easy fitting
???2. Injectors?? - I think the stockies will be at around 90% duty cycle at this power level?? - from peoples experience would this be ok? I know you can get a rising rate fuel reg but think this may be a pain to play with..I guess S15 injectors are an alternative
?? 3. Fuel pump - my stock one showed no signs of fading out up high in the rev range. can 230rwkw be had out of the standard pump? Is a 2nd hand R33/34 GTR pump a direct fit and much better?
Will I need around 15psi to get this power level? I would like to avoid adjustable cam gears and replacing the exhaust. Would a split dump really be required. I have a 3" bell mouth type..
Thanks for your help.
I assume 220-230rwkw would be a fair improvement - without the worry of the turbo wheel spinning off..
Edited by benl1981
https://www.sau.com.au/forums/topic/154786-stage-2-mods-r33-rb25det/
If you currently have a PFC + Boost controller + Full 3" exhaust +GCG high flow... you need:
- Split dump/screamer front pipe (10 - 15rw/kw gain over 3" bell mouth)
- Z32 AFM
- Deatschwerks 555cc injectors ($555 delivered)
- Walbro intank pump ($300 supply & fitted) or Nismo/Tomei ($370)
- CRD/Just Jap FMIC kit ($350)
If your engine & turbo are healthy + decent tune then you should be seeing 240 - 260rw/kw
Cheers
FMIC: If you want to keep with "same sided entry type" i would suggest going for a Blitz LM fmic kit from nengun, they use the stock return pipes, i think they cost somewere around $1000 which is about twice the price of a cheap chinese intercooler kit which would problly do the same job as the blitz kit.
Injectors: The stock 370cc injector have been used for a few 230rwkw cars on this forum that i have read about, if you decide you want to make more power go for the nismo 555cc injectors, they are a straight bolt in injector and dont require any plug or fuel rail modifications.
Fuel Pump: I wouldnt use the standard pump for anything over 200rwkw, most people replace the fuel pump for good reason when they have fmic,full exhaust, 10psi etc etc, they seem to get tired pretty quickly and cant pump enough fuel, i would replace it with a nismo or tomei fuel pump as they are both once again and full bolt in replacement and both come on there own bracket,filter bag and all the other bits and peices, which means to dont have to muck around with modifing things like you would have to if you went for a bosch or a walboro pump (stay away from these)
The 3" bellmouth dumpipe you have sounds fine (depending on who its made buy ofcourse), i wouldnt bother going out and spending more money on a split dump, i too will be going for a 3" bellmouth style dump/front pipe made by Unique Autosports.
But if you only want to reach around 220-230rwkw then the mods you have listed are pretty much spot on, it should make that power on about 12-14psi depending on the condition of your motor ofcourse
Good luck reaching your goal >_<
Edited by nizmo_freek
Thanks for the ideas fellas.
I believe the Rb25 AFM is good up to about 240rwkw...from what I've been reading so I don't plan to replace that
So you think the injectors may handle around 220-230 rwkw..what duty cycle should I expect?
Edited by benl1981
stock afm and injectors will be ok for 240rwkw
they will be on border line but should be ok
fit a fuel pressure reg so you can squeeze a bit more out of the injectors
make sure you replace the stock fuel pump too
you might get 220 - 230rw/kw out of the stock injectors but you will need a rising rate FPR and your duty cycle will be close to maxing out... I dont recommend you max them out too much otherwise you will be looking for an engine rebuild...
Strongly recommend a Z32 AFM over the stock..
For Injectors ($555) + Z32 AFM ($250 - $300) will unlock approx 20 - 40rw/kw with a high flow GCG + tune...
Do it once, do it right or dont do it at all...
Cheers
I would think you'd pretty close with just a tune/boost increase and a FMIC. AFM bypass is a good cheap way to flow more air while still metering accurately also. Issue 318/319 of autospeed.drive.com has a good article on it.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
