  • Replies 43
I'm teh anti-myspace police here and I say you should all abolish your neferious ways before the evil Steffano Palazzi with his dark minions Micheal Jackson and Elton John descend upon you in your sleep.
Edited by Pauly33GTS-t
https://www.sau.com.au/forums/topic/161244-myspace/#findComment-2994837
Your a Knob Paul. LOL
Become part of the myspace craze.
I have no idea what to do to make it pretty and have all the fancy colours and stuff like that.
I just got told how to put Linden Reynolds Promo video up to promote him as a driver and promote drift as a sport.
It's just somewhere else to meet people and chat to friends.
Now I have added a few ppl off SAU.
FLick being one of them.
https://www.sau.com.au/forums/topic/161244-myspace/#findComment-2995450
lol at west end draught sif you would add them :dry:
Whats your myspace link?
Peeps mine is in my sig if you wanna add me :)
https://www.sau.com.au/forums/topic/161244-myspace/#findComment-2995513
hey add me 2 myspace!! www.myspace.com/agechamp
Done.
Add me!!!
Id add you but im new and have no idea how to do things on it lol!!!
http://www.myspace.com/164952954
Done,
Done cept for da bear one.
okies i added peoples.
if people wanna add me heres my link http://www.myspace.com/pokie87
Done.
Done & Already a rpmlounge member.
There you go boys and girls.
http://www.myspace.com/brentonjones
DOnt you go hating me cause im the cooler kid on the block and stuff. LOL
As I said i have no idea how to put the backgrounds on and shit like that.
Done.
https://www.sau.com.au/forums/topic/161244-myspace/#findComment-2996263
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
