hey all,
In this time i crazy about suspension between Tein Super Street amd G4 racing..
I know tein is good suspension. but i dont have any idea about g4 racing.
anybody use the g4? and please recommand other compnay as well..
thanks,
Lance
https://www.sau.com.au/forums/topic/168681-recommand-suspension/
Mate, 1 piece of advice I'll give you is whatever suspension you choose make sure it's not too hard. A lot of people race out and buy the hardest coil overs and the biggest wheels they can fit and the problem with this is it just plain makes the car dangerous. The back wheels have no give and simply break traction and axle tramp under the pump. They also don't absorb any of the cars inertia during cornering and can cause the car to unsettle over bumps during cornering. Last of course is the ride WILL drive you nuts, far too hard! I've fallen into this trap and will never buy HARD suspension again unless the car was going to be purely a track car. Hope that helps.
I have the SK group but stuff in my car and the only place in Vic that its too soft for is phillip island... so unless your going to be hitting PI often the Bilstein whiteline combo is great!
I have never driven on the Tein super streets or the G4 stuff but I can tell you buying 'adjustable' coilovers is a waste of time... do some more reading on shock technology and handling and you will see what I mean
I have the Bilstien setup also however I have slighter stiffer spring rates than the SK GB. Car goes pretty well, just need to learn how to drive it consistantly at DECA :laugh:
my issues is the stock diff now. 1.5 way comming my way soon.
Tein: Great Japan quality. If bought through Fulcrum, they are re valved/sprung for Australian roads.
G4 Racing: Cheaper quality, not sure where they are made. Will not perform as good, in the long run.
Even though the SK gb kit are great, i still prefer my adjustability. I like the thought of adjusting the stiffness for various roads, events, conditions, etc. And the Tein EDFC makes it soooooooooooooooo much easier :D
I disagree with the coilover statement, height and dampener adjustment is very useful. Height is good for raising if the cops pin you and dampenr is great for fun/track days and other events.
Lance - What are you looking to get from your car? What will you be using it for?
Mate I was raped by Pettett last week and he was picking on my ride height. Now I know for a fact that it's sitting at 110mm at the pipe (lowest point) but he STILL gave me a hard time about it. The fact I can raise the car for testing is priceless. All you need is one assho|e cop like him and you'd have to get a lot more work done to raise non adjustable suspension. Now I know you'll say "make it legal ride height and you'll have no issues" but we both know that aint the case huh.
All I'm saying is the SK group buy for instance is almost the cost of a set of Tien Super Street (Fulcrum local stuff). I'm about to change my suspension and I know what I'll be choosing.
fair enough then!
yep you have to take the Bilsteins out to reset the height... but I have never been pulled over let alone hassled about ride height... I have mine set pretty high though, otherwise the tires scrub really badly on the rear guards... you should move away from Knox!
I know you've been raped... more than once... :)
lol
Ye i know that, but if you are sitting 110mm, why are you even raising it?
Your legal to begin with!
ive got tiens and they are pretty stiff.. but id rather a stiff ride (yeh i know that sounds gay) over bodyroll anyday
Only thr Jap Spec are stiff.
If you bought them through Fulcrum they would be ALOT better and comfortable. Yet the still have enough dampner ajdustment to make them pretty damn stiff.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
