rb25 beemer
I've seen a RB25 in an E30, it was being done by Rollins Imports on the Gold Coast (ads in zoom if you want a no.), the actual engine fitted ok (remebering that the BMW engine bay is already designed for a straight 6 engine, but they did have issues fitting in a radiator and intercooler, so you might want to see if you can ask them about that. I've just put and RB20DET (which is the same dimensions as the 25) into my '77 520i, and it fits beautifully, looks like it was factory, but i've probably got a bit bigger engine bay. I also have no room for a FMIC, i'm running a top mount water-to-air jobbie. Thats more related to the front bar design on my car though, so you might be ok.
I notice you're in toowoomba, if you want to come and check my car out sometime (not that it's verry impressive atm), even just to compare the size of the engine bay, let me know and we can arrange something.
Hope that helps in some small way,
Cheers
Belly_up
Hope that helps in some way
https://www.sau.com.au/forums/topic/16887-rb25-beemer/#findComment-348433
Forget it, too expensive. I had a E30 ('85) 323i rebuilt as as 2.8L. The thing is if you want a RB, you'll have to change the tranny and diff too - i popped 4 diffs. Get a 3 series inline 6 second hand, drop it in with the box and diff and turbo it. It wil boogie.
Heres some links for you:
http://www.bmauto.iinet.net.au/
http://www.bavariacars.com.au/
http://www.kormanfastbmw.com/
http://www.bmwe30.net/
I miss my E30 beemer :spank:
and heres a pic :(
https://www.sau.com.au/forums/topic/16887-rb25-beemer/#findComment-348959
the other thing to look out for is that the BMW motors are intake on the the passenger side, exhaust on the drivers side, whereas the nissans are the other way around. So you'll have manifolding in different places from normal. for me this was a good thing, as it gave me more clearance for exhaust manifolding (my beamer has a huge steering gbox on the drivers side, i think the e30 i saw was much better in that respect), but it might be different for you.
https://www.sau.com.au/forums/topic/16887-rb25-beemer/#findComment-349043
yeah, about 6 months after i started my RB20 conversion, i found out that if i'd looked in the right place, i could have done the BMW motor for much cheaper than what i originally thought. Although if you want to go the turbo route, you're up for a turbo, custom exhaust manifold, intercooler, possibly injectors, possibly decompression of the engine, and definately aftermarket ecu, all straight away, whereas the RB25 already comes with most, if not all of that stuff.
https://www.sau.com.au/forums/topic/16887-rb25-beemer/#findComment-349419
I can vouch for Belly_up seeing Rolin Imports dropping the RB25DET into the E30 Beemer. It was a black car by memory. The stage i saw it in (this was well over 18 months ago) was when they just lowered the engine & tranny into it with the fabricated mounts. they were struggling for engine bay real estate, that's for sure. they had to actually cut a piece of the Rb25 timing cover to clear one of the intercooler pipes which crossed over. very tight fit. the car sat very low (stock springs?) with this engine. the guys there doubted its weight bias front to rear. i doubt it would have handled well being front heavy. i'd go down the SR20DET path if it was me and i wanted a great handling chassis. but if straight line stuff is more the go, then by all means, the RB is still a great choice.
https://www.sau.com.au/forums/topic/16887-rb25-beemer/#findComment-350452
The 'big block' 3.5 straight six is more of an effort to fit compared to a 2.5 twin cam or 2.3-3L from a later E46. The block of the 'small block' inline 6 hasn't really changed in the last 20 years (virtually the same external dimensions), so it is much easier to drop in with minor crossmember mods etc. By memory all that is needed is a sump modification - it wil fit with stock engine mounts.
The 3.5 is also a fair bit heavier, whereas the twin cams from the later E36 on are only marginally heavier and will not disrupt the balance as much. They will more or less match the older big block single cam straight sixes for power, but less torque.
I would seriously stick to the small block twin cam six from a later car. Make sure you check out the BM Auto Engineering website i posted above - they have done E36 M3 engine / gearbox transplants into E30s and they fly...
https://www.sau.com.au/forums/topic/16887-rb25-beemer/#findComment-352361
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
