Had a good time watching all the cars ... was wondering what some peoples results were ... the best i can remember was most skylines getting 13's ... martin soarer doing low 13's ... an old school skyline doing 15's (about 45 times too i might add :P ) ... and excel in the low 13's ( i wonder whats under the bonnet??) ... that red rotary drag car doing a 9 something and made me deaf ... keirs 32gtr with a 10.42? also made me deaf ... lots of commies in the 13's 14's ... falcon with a 12.9?? oh yeah ... evos with low 13's and 180's in high 12's??
correct me if im wrong ..
https://www.sau.com.au/forums/topic/17154-drag-results/
Very nice times there man! It certainly looked the goods.
The whole car was twisting and rocking at the 1st/2nd gearchanges - I was sure something was bound to snap with all that force/grunt! What mods do you have? Did you import the car yourself or is it local realease? (not sure if they sold them here or not).
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355002
my friend with me has an evo4 ... he didn't race it and it was parked outside with next to my car ... it used to be 224kw@all 4 ... that was with a hks turbo ... and motec computer tuned by rpm ... he never races his car though ... hes since taken out the big turbo and made everything stock agian ... lookin to sell this evo4
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355087
Good to see everyone out and finally put some faces to names.
I did 13 passes and my clutch didn't even stink on the way home!! Even though the commentator (Andrew I think) thought I was trying to fry it, with so many runs in a row.
The track was bloody slippery at first but good to see some nice rubber laid down throughout the day. I finally broke into the 12.4's running 15PSI with a 12.421 at 110.26MPH (60' 1.835sec).
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355619
Great day, thanks Ivan & crew from RPM. First time I've ever done it and was good to drive home OK (apart from a now leaking exhaust manifold that I'm told is no big deal for a while!).
13.42 ET, 106.5mph, best 60' was 2.11s.
Main thing is that I beat grepin, Chris32 and Bugalugs :burnout: Dare I say quickest GTS-T on the day! Bugalugs' run were amazing though, 13.44 I think and 106.99mph!! And that's with a stock ECU...good stuff.
grepin, do you now surender? Do we declare WW1 has been won by Freebaggin .... or should we wait until after the climactic battle this Sat at Tilbrooks for the outcome of WW1?
Then WW2 starts soon after!
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355737
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
