I still think he knew about the dump pipe.
no doubt about it - someone on the forum must've leaked the info!!!
then again it could've just been an angry driver of an is200 who found out i ploughed his wife. don't worry man, i was very considerate and i know the rules - up the bum = no babies :thumbsup: s'all good.
  • Replies 72
roflcopter...I'm an A grade wanker to A grade tools...Josh and I have that in common...you all <3 us though!!
Hugs all round...except for you Mark...you and your freaky coconuts stay away :thumbsup:
Hahah, its true. We have such an A grade wanker skill dont we Matteh
josh is cool..
keegs u really are a wanker..
Unfortunately you only believe this because you're an A grade tool, and as previously mentioned...I have a compulsion for being a wanker towards A grade tools. Take a tissue and build a bridge marki.
... tsk tsk.. indeed school holidays are in.. buidling up ur E-wang are we..?? also ur such a mighty key board warrior!
Taking things a little to seriously are we? Getting a bit cut up? Don't self harm tonight Marki, razors are not your friend.
asif black ppl cut themselves yo.. dont u white ppl with ur depressants cut urselves... i dnt knw why ur sad.. ur white... SMILE.. think thats off the longest yard.. haha
your all a bunch of f**ken heros hey lol
lol.. :) great post..
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
