hey guys. just wondering on what goes on, on resealing rear windscreen on a 32 cause the guys that did it before just took the seals out and just filled the gap in with sugaflex. now they are saying that the windscreen has to be pulled out then resealed. now i am just confused cause this was just a half finished job. could ya guys help me out here got the pic attached
thanks
https://www.sau.com.au/forums/topic/178304-windscreen/
yeah from da looks of things.... ur rite gonna have 2 pull it out and re-seal it....!!!!!
and da new moulding 4 da rear window is round da 500 bucks mark thats da complete seal kit genuine from nissan
im bout 2 re-do mine...!!!!
Please talk properly like your mum raised you to.
https://www.sau.com.au/forums/topic/178304-windscreen/#findComment-3254220
You can use another type of seal, I think it is an early CommonWhore item. Not to sure on the model, I will try and find out for you, However, the fit and finish will not look as good as a Nissan jobbie, I know, I have just done front and rear screens.....
Mike
P.S
That is a shitty half job, I would tell those rude bastards to pay for the R&R of the screen, seeing as they were so quick to take your coin, but then do a sub standard job.
And If they don't like what I have to say, tell them to come talk to me direct.... I like handing out pain!
Edited by MIKE_R32_GTR
https://www.sau.com.au/forums/topic/178304-windscreen/#findComment-3255927
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
