Abe I'm 99% sure it's the video card. It stuffed up about a yr ago, replaced with a second hand one where the fan wasn't working properly for it.
Any idea where to get a basic video card from? Don't use the comp for games etc so just need a basic one.
Cheers.
ur diagnostic skills are fail... =P
if i was a betting, wow, i'd probably put my car up on it not being the video card =D
could be soo many other things making it do that... number 1 is the power supply! i'll also throw my hat in the ring and offer u some free help, just lmk
ps. hoodie thread up soonish
Luke, i just worked out what it is... =D
but i'm not going to tell you what it is because if you try to fix it and mess up you could end up killing stuff!
however i will say this, whoever you take it to will set it up and it'll probably turn on first time, straight away and u'll both be like "hu?" =P
^ what a graph card that's not seated correctly in it's slot?
wow, i should actually start taking bets with people on this! =P
no, as i said before, nothing to do with vidoe card... unlikley that one would just randomly pop out!! =\
Tell tell..... I'll give good prices on jap stuff lol
just drop round and i'll fix, fix!
edit: and coz u get me good prices i wont slug you the $40 i would to a customer for fixing it =P
Edited by Fishpaste~
With big turbos cams can make you up to 50kw depending on the size of the turbo and the amount of head work done as they allow you to move the turbos into their efficiency range, but like chad said with small turbos they won't affect peak power much but will allow you to move the power around the rev range and can get you some nice gains on torque.
Here's some graphs from when we were playing with the cam gears on my car.
cheers man, might go ahead with these os cams
see what willal can do with them once i get a new exhaust fitted
Hey guys, I was wondering if any of you have heard of GT Autosound in Glynde, and if they are a reputable workshop. Thanks in advance.
yeah their pretty good their man and reasonble prices with what you get out of it
Sweet. How long u reckon it would take? Have to head down to Marino around 9am so could pop by after that?
Cheers.
prob 15 mins all up... thing is i'll be at uni from 9 till 4 tomorrow, then have district basketball
so either drop round tonight or tuesday!
u gonna be up for abit still? If u are I'll pop around soon.
George and Theo are excellent guys. Havn't had any work done by them, but never heard a bad word about their work :ph34r:
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
