Hey guys,
I have another switch question. I picked up my S2 Manual Stagea and have seen a switch on the dash which is to the right of the steering wheel.
It has a pic of the windscreen and wiper and also looks like it has a wavey water level at the bottom of it. If I press it the only this it does light up an orange light on the switch itself.
Sorry if its hard to explain and my camera is buggered at the moment. The switch also is not an on / off switch. if you press it down it will flick back up and the light will come on and if you press it again it flicks back up and the light turns off but it doesnt seem to do anything.
Im assuming it has something to do with the windscreen of washer bottle but I have no idea what it would do!
Cheers
Dave
p.s. I am loving the stagea!!! I had no idea they were so nice to drive!
https://www.sau.com.au/forums/topic/191695-dash-switch/
hahaha well i dont think ill be using that any time soon, cheers.. I guess I can't really test them then? how does it work?
Put your wipers in the freezer for an hour, pop them back on, time it with/without switch on to see how long before the defrost. :laughing-smiley-014:
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3448454
The "Wiper de-icer system" usually came with a cold weather spec pack which also included heated wing mirrors, rear fog lamp, bigger battery, better heater, bigger starter, & if you coupled that with the "S Pack" you would get a rear viscous Limited slip diff (LSD)
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3452124
and the remote start option maybe? or is that something else again?
'Fraid not, the remote starter was a seperate option...
Type A starts or stops the engine
Type B starts & stops, alarm function, locks & unlocks the doors.
Type C starts & stops, alarm function, auto rear demister if ambient temp is less than 5 deg, and answer back function
Type D starts & stops, alarm function, lock & unlock, auto rear demist, & answer back which basically sends a signal to the car (at up to 300m away) the lights on the car flash, then the little LCD screen displays the car temp, if it's locked, if the alarm is armed, and if the engine is running or stopped among other things...
All of these were only available on the auto
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3453336
Holy crap. That's just the remote start options???!! I'd choose... type D :(
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3453531
Nice, my stagea just keeps getting better... It is the 'S' and has the rear fog you mentioned as well.. I love it, I can't believe it took me so long to decide to get one!
rear fog? whers that ands more importantly where is the switch?
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3461215
  • 1 year later...
rear fog light is for they really foggy days, say if you can just see the car up ahead that is only 20meters or so infront, well then i guess the car behind you can just see you too.
fog light is really bright, and being red they will know that there is a car infront and thats your car they can now see.
little switch is for the wiper arm, if you have snow on your wiper arms, thick snow, that basically heats up, melts the snow around the arm to allow it to move much easier. :D
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-4451083
Hey there
The switch that you are talking sounds like it could be to heat up your wipers, you can tell by having a close look at your windscreen, if it does have the heating elements in the glass they are orange in colour and usually have three long strips where your wipers sit in the off mode. If the heating elements are in the black part of the glass (ceramic) it will be very hard to see but you should see them.
If you do happen to have the heated windscreen make sure you have glass cover on you insurance, if you think the price of a normal windscreen for a stagea is expensive wait till you find out how much a heated one is!!!!
Edited by Punk72
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-4451095
the switch heats up your front windscreen... if you look at your windscreen you can see a few lines of that demister strip around the outside... turn it on for about 5 minutes and touch the windscreen near the strip, nice and hot... i didnt know it heated up the mirrors... will come in handy in winter when im down at the snowys...
p.s. i was lucky enough to have remote start type b... theres a few tricks to using it tho which is good... push the start stop button twice the car starts... push it once it stops... push the other button twice alarm arms and locks doors, once will disarm and unlock... only thing that shits me is once the car is running it will turn off when you open the doors... i am thinking of a timer circuit that holds the door switches on for like five minutes so you can get in the car put the keys in the ingnition... as soon as the keys are in the ignition its orite... if you have the window down and put the keys in the ignition its sweet as so it wont be too hard to come up with a circuit...
neway ive got a stagea to wash
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-4451745
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
