cardio and the right diet would be more effective.
yer im very skeptical bout this kind of stuff...
but the reviews ive read are really convincing while others ppl say its not that great.
just wondering if anyone has had it/taken it? and what they rekon?
there is a health food store near me that sells it ..
its really only the caffeine in it that helps though ... it helps to raise your resting metabolic rate
when I diet if I want an extra edge I use no-doze caffeine pills ... you can get 100 for like $20 or less from your local chemist ...
pop 2~4 b4 cardio and 2~4 before you push weight and you'll notice a big difference!
finally a helpfull post....
oh ok thanks mate, will try that :blink:
cheers
*thread close*
However if u want an even bigger edge go for the no-doze plus..theyre a bit more expensive than normal ones but they give u a whollop of energy :domokun:
Edited by vinnie34gtt
lol @ using caffine pill in place of an energy supplement... (no-doz ftw!)
ive been using bsn no-explode as an energy supplement...thats some crazy stuff aye.
so i take it noone has used it lol
I had good success with the EAS 'BetaLean' product back in 2005... They don't make it anymore but they've replaced it with something else..
'Dynamx' or something like that... I'd reccommend it, but you need a good diet and adequate exercise to go with it...
Gaspari nutrition has one called Cytolean, is the best iv found atm, tried hardcore, lipo 6, tried to get a new lipo 6 product in but customs took it :thumbsup: next time il be going ECA, see how that works.
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
