Hmmm, might even be best speaking to Terry about this one, I like to think i know a lot about supplements but still nothing in comparison to him. Dont want to lead you down a garden path if im not 100% correct.
All good man, appreciate the insight regardless.
lol fk off Troy ya tub of lard :P
Does anyone ever get headaches / hangover feeling from certain proteins or supplements? My favourite brand of all-in-one supplement has changed something about their mixture (hadn't ordered from them for nearly 2 years) - this one smells kind of fishy and clumps up a bit more than the previous mixture, despite the breakdown label and taste being much the same. In the first week of using it I had some slight headaches on and off, but could just be coincidence, I might have had a bug for that week.
Sounds like a bad batch and you should return it to the store Birds? Did you buy more than one tub (check the other)? If it smells fishy that's no good.
Can't say I've really had headaches from supplements, only sleep deprivation from the caffeine.
This thread is starting to look dead so thought i would add some of my progress...
Recently started a 5x5 program to change it up a bit. The idea being 5s sets of 5 reps so obviulsy heavy. Then try small prigressions in weight for the next session
The key focus for these lifts are 100% technique and full range of motion. This is important so I dont cheat in the rep just so I can say I got all my reps and it's time to up the weight next session.. Upping the weight should really only occur when all reps can be completed without a spot or maybe failing in the last rep of the last set.
I've found this routine to be pretty good, done 4 weeks now so will probably only do another 1-2 weeks before changing it again..
Some examples of progress are
Weighted heaves
Started at 10kg doing 5x5
Last session was 20kg 5x5 with a fail on the last rep of 5th set
Weighted dips
Started at 20kg
Last session was 40kg 5x5
Deadlifts
Started at 140kg 5x5
Last night did 150 5x5 (really should of done 155 I reckon but pussied out)
Barbell lung walks
Started at 50kg 5x5 (5each leg so 10 reps)
Last session 65kg 5x5
Squats would be a good one but I've revised my technique so really I've gone backwards
Edited by GTR_JOEY
What's your weight?
I'm almost there myself; couple kilos off. Granted, I only attempt the 1RM after my 6 sets (OCD thing).
Some might be pleased to know I've relaxed my philosophy on restricting what I lift in order to keep my body weight down and balance the body shape. Have let lats do what they want (haven't stepped these up for 2 years), 5th and 6th sets on pulldown are now 220 pounds instead of 200...another 30 pounds and I've cleared the whole stack teehee.
Might have to look at weighted pull ups then!
Competed at GPC Nationals about a week ago.
Weighed in at 91.4kg
Squat - 190kg
Bench - 110 kg lol
Dead - 220kg
All PBs for a proper 3 lift comp.
As single lifts, the squat was a 5kg pb, bench was 5kg under pb, dead was 2.2kg under pb.
Most importantly I didn't cripple myself.
Next one is end of August. Hopefully bench will improve if I can complete my lifting plan without elbows and shoulders falling apart.
Edited by TTT
decent lifts.
First session back in the gym for a couple weeks. Must say the lack of diet and training for the period has hurt my progress. Was much weaker then before and have noticed it in my appearance.
Not to worry, hopefully wont take me long to get back to where I was and keep on going after that.
What's your weight?
I fire the same question at you Birds, what is your weight?
Currently 80kg @ 6'3
1RM for bench is 115, done after my usual 6 set workout and taken to an inch from my chest. Tried for 120 but failed half way back up...confident I could pull it off with just a warm up and straight into the 1RM!
Can anyone here strict military press their own body weight? That would be impressive
1 rep? In front or behind neck? Doubt I could do my own weight behind neck, but again, it's an exercise I've left dorment with regard to stepping up. Might start increasing it now that I'm doing that with every other exercise.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
