I'm slowly thinning on top, must be the governments fault.
Ain't nothin' slow about my thinning Yo.
This is a story all about how my life got flipped, turned upside down And I'd like to take a minute just sit right there, I'll tell you how I became the prince of a town called No-Hair
had a guy notice me doing cuban press, face pulls etc yesterday, gave me some good pointers with other prehab type exercises I could do (turned out to be a doctor).
Birds that sounds like something the pro BB in our gym would inflict onto one of his PT clients, except for the fact that he dosen't squat so it would be leg press and calf raises lol. how long did it take you to recover afterwards?
Not long til I could stand again, but my legs were cactus for the rest of the night. Dropped down from the pull-up bar and my legs had trouble standing back up etc.
I guess where this shit gets you bad, is that when you are squatting a big weight, your leg and back muscles will go until they can no longer push up another rep of that big weight - but that doesn't mean they don't have lots of strength left in them - just not enough for xxxkg. Hence you can stand easily afterwards under just your own weight. Drop it down to something light, like 60kg, and your last rep at this weight is more likely to drain you of any remaining strength, to the point where you can't support your own body weight for a minute or two. I imagine body squats with no bar would do you even worse.
Give it a shot sometime, after your heavy weights!
I used to think I could do that with 40kg, was trying to prove a point... got to 30 reps lol
Funny this, I don't remember you conceding your point to me; seemed to forget all about it :P
I really have no idea - the most I've done is 64 reps of bodyweight in the 8x8 setup for Tabata!
I tried it again lastnight with sets of 90kg. Back hates me today. Did better in squats lastnight than normally, so I'd say the huge set of 60kg helped somewhat.
Probably :)
But we know I'm too stubborn for that...and my old pb was based on a 1RM after working sets,
However I have switched my squats to that style (1RM before working sets), as they were actually on a severe plateau that I couldn't break through with any other way.
Probably :)
Birds, stubborn?
:whistling:
  • Like 1
Stubborn Birds got a 115 bench tonight, so another 5kg and we are home for a new pb :)
Though thinking about it I never used to touch chest; it was always within an inch of it, so I'm probably actually stronger than I used to be.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
