Hello Everybody,
3 Questions
Can I put an Air/FUel management system in an L24 engine, If so what brand would you suggest
Is it safe to use octane booster in an L24 engine?
If I replace the fuel pump and put in a new ems is it safe to run nitrous oxide
https://www.sau.com.au/forums/topic/209423-r30-skyline-questions/
Okay thanks everybody,
Would an apxei air fuel computer be suitable ive heard things about incompatiblity with sensors but im not sure
And the reason for nitrous oxide is that i told someone I wouldnt use a turbocharger/supercharger in it and they bet I couldnt get a peak over 250hp without the turbo
gonna hook 1 up 2 my l24 (r30) if any1 has done 1 b4 some info would b great, cos bit un sure of what wires i need etc. also any1 have instruction manual 4 the old skool type apexi afc? like single dial type. only has 4 wires.
cheers...
might just add to this thread if i can.
after i hooked up the afc, the best i can get it 2 run is upto 2500rpm. can hear the engine change note when adjusting the afc so guess it works. but will just die in the ass and stall after that. changed all the switches at the back etc and best is it will work upto 2500rpm.
any1 installed 1 of these 2 a l24 etc b4? also any1 know the voltage range of the afm? think has 2 b around the 0-5v for it to work
cheers...
Screw the NOS. Tripple dual throat carbs, aggressive cam, agressively mapped dizy and timing, agressive head porting, tune length extractors with matched exhaust, bore the bastard or even drop an L28 in with a diesel cam to increase the capacity and then do everything else I talked about. I've seen a 400HP Carbied L28 in a 240Z. You don't need fake power. Make it the old fashion way with massive amounts of fuel. Mind you a 30km road trip was a 20 dollar fuel bill. But hey it went.
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
