Hi,
Ok, well I think I'm still missing something....
Q1.
Why is it that a small turbo producing lots of boost, but low flow induces detonation, but a larger turbo with lower boost but more or the same flow will not detonate ?
/Professor Julius Somner Miller "Why is this so ?"
Q2.
I have a GCG500HP Hi Flow Turbo - and I am seriously thinking of a RB30DET conversion - How would this turbo go with the 3.0L Block ?? Anyone done this already ?? On the RB25 Boost came on at like 2200RPM (full boost at 3500) I would expect that on the RB30 I'd be starting to boost at 1500RPM (full at 3000). Would my turbo still be able to pump enough air at 6500-7000 RPM with the RB30 ?
Q3.
I'm going to build the RB30 to be able to cope with 26PSI. With forged rods and pistons etc. If the GCG500HP is too small for the RB30, what would be a good turbo for boost from 2500 thru to rev limit, ie not much lag - Not looking for HUGE power, just good useable, effecient power accross the rev range. Also Turbo should be low mount, stockish looking (ie not stand out high mount)
Q4.
If the GCG500HP is good good for 500HP (372kw) at the flywheel. Factoring in the 52kw driverain loss - and everything else being equal. Theory says that I should be able to attain 320rwkw. Is this realistic ? Or not & why ?
Cheers all
https://www.sau.com.au/forums/topic/21339-more-turbo-questions/
Yeah, maybe not with current turbo - Since current turbo is still fairly new, one option would be to sell it and get a bigger turbo. But I like the responsiveness of my current one. So choosing a new one and factoring in costs versus benifit is the hard bit. Hence the questions.
Thanks,
Originally posted by B-Man
Hi,
Q1.
The higher the pressure in the cylinder the more heat will be generated on compression stroke the more prone to detonation - this is my understanding its not the amount of air, but the pressure (or boost) that is the problem.
Q2.
Sorry I wouldnt have a clue how it would go on an RB30 except it will probably be a bit on the small side for my liking:D
by putting on a 3L bottom end probably wont effect the peak power output overly as this will be the product of the turbo and support systems bolted on (intercooler, exhaust etc) just where the power is made.
Q3.
I would personally be looking at a GT35R or similar. Have a chat to Per4manz Turbochargers, they do a version of this that on a 2jz made boost from about 1800rpm and was sitting around 1bar by 2500 - this is from memory, they would be able to confirm for sure. They quoted me $2477 new. They claim 80% compressor efficiency at 1 bar - but wouldnt give me a copy of the map as it was inteletual property. http://www.per4manz.com/
Q4.
Cheers all
Because it those figures are in a perfect world, no flow loss, no thermal loss etc. When a turbo is rated at xxx hp, that is in a 'perfect' test environment.
Hope I havent led you too far astray with any of the answers, just passing on my understanding and hope that I have come close to the mark.
Hope the new donk lasts a bit longer than the old one:p
Not at all Steve, always appreciate your knowledge/experience. Thanks.
He He - so do I !:)
I thought as much - current turbo may be too small for RB30DET> But I'm still keen for it.
On with the research.
:P
Did you think of swapping the rb25 for a rb26? If you had, why are you choosing the more expensive 3L option?
so your selling your turbo huh?.... someone I know may be interested :)
Could you PM the quotes for any rb25 rebuilds you have had?
good luck. Can I go for a ride when your finished?
Mark
Mark
Hi Mark,
Yes I thought about an RB26DETT - here's why I didn't :
2nd Hand motor $6,000
plus ECU
plus Sump & gearbox mods (not sure if required)
plus fitting
plus ECU
plus plus plus
Still not new.
RB30 DET = brand new motor
Not neccessarly selling my Turbo - just and option at this stage. Still researching.
re: RB25DET rebuilds - the range is awsome , depending on what you want of course. - $6000 - $15000
Of course I will take you for a ride, no worries ! I got to get it built first, which means I got to save $$ And work out which way to go - As far as I can see, all the performance shops push what they make the most margin on. Which is OK in isolation, but when you are talking a package deal, you think that the scale of economy would kick in !
Cheers,
:P
Hi, If you want a package deal that has a fixed price and you know exactly what you get, try this.
RB30det rebuilt, stage 1 with custom intake system (series 1 or 2)
Stock pistons,rods,crank. Stock R32 RB25 head. 8.3:1 compression ratio. Stock exhaust manifold. Stock type throttle body with 15% larger butterfly and flowed intake, twin inlet fuel rail, No turbo, No injectors, No electrics but comes with everything else in picture as well as custom cam cover that fills the gap from having a taller block . This is a base model motor good for 250-280rwkw reliable. NZ$6000+gst (if any) for a 2WD or NZ$7000+gst (if any) for 4WD.
If you want just the long motor, ie no inlet or exhaust manifolds the engines are NZ$3500 +gst for 2WD and $4500 +gst for 4WD.
We have found them ideal for someone who already has a FMIC, computer, exhaust, fuel pump etc and wants strong low-mid range drivability as well as a good top end.........Regards Rob
Hi RIPS,
That's quite a plemun - How is the inside of it done ?
BTW - I was the one on SDU that asked you about the RB30DET with forged internals (brendanf on SDU)
You got me thinking some more now.
Nice Pics.
Cheers,
B-Man the NZ prices should be GST exempt for export too. :D
Combine that with the exchange rate and there's some more food for thought. :D
nb. This advice is not given free of charge. The afformentioned turbo will suffice as payment.
Just think how much I saved you!!! :D
Originally posted by Craved
if you want info on this setup, even with the rb25, you might want to look at the HPI R34 --- just got 291KW at the wheels, will give you an idea of what is possible!!!  think they are similar turbos too!
The turbo on there is a HKS 3037 - he upgraded from the GCG one he had as he wanted more than the 240?oddrwkw.
RIPS - any info on what sort of freight cost would be involved - also do you know if customs will be hitting duty+gst to bring from NZ to aust?
What sort of prep do you do to the internals, I noticed you said stock internal, but have they been balanced, blueprinted, crank nitrited, rods linished, shop peened crack tested?
Do you sell short motors, just with relocated belt tensioner and larger cam belt as a bolt up arangement for someone who may have an RB25 head already? What prep has been done to the block? Has the head been ported at all? What cams do you use? Does your plenum include a fuel rail?
And, which oil pump do you use for the RB30 block? do you fit piston oil squirters? What bearings do you use? If you are getting 8.3CR does that mean that you just using RB30E pistons with a RB25DET head - no decking of the block or head?
Thanks
Steve
B-Man sorry for the whore, but it looked like you may be interested in the answers as well?:D
I will have to look into freight etc. There's no problem getting a motor out of NZ, but you may need to check your end as to what you will need to do.
Go to "I need help with plenim" further down the threads, there are pix and info on what you get with the plenim kit.
All our motors start with a acid dipped block, crack tested crank etc, but for the base motor its all very stock. There are alot of tricks to get them to hold together and just to show you what can be done with a properly prepared and tuned stage 1 RB30det, I'll include a roller dyno run. With the bottom of the range R.I.P.S RB30det with 75hp of NOS, we made 342rwkw by 5500rpm, then the clutch blew. As you can see it was still climbing hard and now that we have a real good clutch we should be able to go to 400rwkw @ 7000rpm for short bursts (ie drags)
I just wanted to prove that you don't need flash this and flash that to make a good drivable 250+rwkw, and for the price, I have not seen better value.........Regards Rob
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
