Hi all,
so it's been a few months since i've had SK's bilstein/whiteline shocks/springs in the car, along with camber kits (set to Sk's specs) and adjustable swaybars.
Swaybars came first, and the difference was quite noticable. Initially set full hard rear, and full soft front, sat a lot flatter, but always wondered if it was set a little too tail happy....
Springs/shocks came after and car sat flatter again, felt alot more solid and planted on the road, but i had the swaybars put back to the middle settings before a track day (both front/back bars) as i thought i'd try for a more neutral setting.
The question is, how can you tell if you have too much oversteer? I could get the TCS light to come on fairly easily out of a corner at Sandown, and i don't really have major power mods either.
So how do i know if it's just the tyres losing grip, just too much power being put down, or that i have too much oversteer?
I'm not really knowledgeable enough in terms of feeling what the car is doing as the 34 is my 2nd car, and my 1st performance car.
I also think that the car still has quite a bit too much body roll, even with the SK spring/shocks AND adjustable swaybars. Would it be silly to set both front/rear to the hardest setting?
Is there anything else that can be installed to reduce body roll?
cheers,
daniel
Technically you have oversteer if the slip angle of the rear tyres is greater than tht of the front. An explanation which I imagine is about as helpful as a poke in the eye.
Some questions for you which will make it easier for others:
Does the car have an aftermarket diff or a stocker LSD or otherwise?
How does the car behave when you aren't on the throttle?
Do you have some photos of the car cornering?
Traditionally on corner exit you feed as much throttle into the car as you can without making it oversteer too much. The more gentle you are the better it works. Low powered cars tend to be set up so they oversteer more easilly than higher powered cars. It is quicker that way.
Tyres only have so much grip. Look for friction circle on the internet. Whatever grip is being used for turning cannot be used for accelerating. So you need to trade turning performance (ie cornering or generating more oversteer) with traction (ie accelerating down the straight). Broadly that is. Weight transfer tends to make a bit of a mockery of the assumptions....
I would suggest working on your corner entry, concerntrate on balancing the car and making it as smooth as possible, e.i, get your gear changes done before the corner, ease off the brakes onto the throttle, and turning the car in nice and smooth, then dont apply power till you know you dont have to take it off.
Leave your suspension on the middle settings, a lot of body roll & traction problems can be rectified with the device behind the steering wheel - Sorry, I dont mean to sound harsh, but the best thing I have ever done was to have someone who was an awesome driver teach me how ;) I went from thinking I was a good driver, to realising I dont know anywhere near enough!
Edited by Medium Dave
Hi all,
cheers,
daniel
Advanced driving school time Daniel.
In the interim my often published swaybar set up list
I usually start of with the front bar on full soft and the rear on the middle setting.
If it oversteers too much, then I move the front bar to the middle setting
If it still oversteers too much, then I back the rear bar off to the softest setting
If it still oversteers too much, then I move the front bar to the highest setting
If it still oversteers too much, then you might need some more rear camber and/or the HICAS is still working (get rid of it) and/or the rear subframe alignment kit needs to be set to maximum traction (squat)
If it understeers too much, then I move the rear bar to the highest setting
If it still understeers too much then you don't have enough caster/camber on the front
Cheers
gary
hey Gary ;)
i've done 2 advanced driver training days, and 1 day at track day at sandown with instructors on a few laps :wub:
when i had the swaybars installed, i was trying to remember that exact post off the top of my head when i was at the workshop, i went with full hard rear, full soft front to start with, which was obviously wrong for a setting to start out on.
But it's the "if it still oversteers..." that i don't know if it is or isn't... that's what i'm getting at, the feeling, or knowing that is what's happening. As a driver, i guess i just don't really get it. I mean, i know what it is, i know what it looks like, but being behind the wheel and feeling it seems to be a different matter for me.
I guess it's a bit like yourself being able to revalve the bilstein shocks to your specs... not everyone would be astute enough to be to engineer something like that.
I don't have the 'feeling' know-how of it it's just my right foot that is causing the TC to kick in, or if it's perhaps my suspension that is contributing to it.....
djr81: no aftermarket lsd that i know of, no pics of my car cornering that i know of. Good question re: without throttle... do you mean completely without throttle? or just whilst it's not being actively pressed?
kicking myself for not asking the instructor who drove me car, what he thought of it. He was ultra experienced, can't remember the qualifications/history but had been in/around motorsport for a long time.
Maybe i'll go do another day with instructors, let a few different ones drive the car and see what they think. Is something that perhaps a suspension specialist workshop could do? ie.... "tune" or some sorts?
oh and yes, aware of the friction circle, see it a couple times at the Driver Dynamics days....
You cant go wrong going to the next WRX day at Sandown. I or anyone else can jump in teh car with you. Nothing beats seat time and persoanlly i wouldnt be changing anything more on the car until you get your head around driving how it is now.
Get mroe seat time. Get familiar with what the car is doing then go back and do another driver training day to make sure you are not falling into bad habits.
Personally what i see all the time is the first few times ppl go to the track they are using the wring gear. If you want to use 2nd then slot 3rd and you can use a lot more throttle and the car settles down a lot more makign it far more stable. Confidence increases, speed increases, fun increases and tyre and engine wear decreases from pinning 2nd gear to redline all the time with wheelspin
hey Gary :P
i've done 2 advanced driver training days, and 1 day at track day at sandown with instructors on a few laps :)
Sounds like you need to do two things to further your understanding.
1: Buy a book on car handling and or driving. There is a thread somewhere on that & if you go through the titles listed & then check what they look like on Amazon. You can get most of them through the ptistop bookshop in WA if you want to sort them locally.
2. Once you understand what is happenning in a theoretical sense get an instrutor to drive the thing with you as a passenger. Either that or find some gravel roads.
In the interim it may be better to explain a cornering sequence in four parts:
1. Braking.
2. Turn in.
3. Mid corner.
4. Corner exit.
Chances are if you are getting oversteer it is on corner exit and is due to either poor traction from the lack of LSD (Single spinner bullshit in other words) or less likely too much throttle. I would doubt the car is oversteering in the first three stages of the corner.
Hope that helps.
Probably a very silly question, but do you have to counter steer when it happens? If not i'd say you are just too agressive with the throttle on corner exit and the tcs is effectively modulating the throttle for you. I'd suggest if you aren't countersteering when the lights flashing at you then the car is probably neutral enough or maybe even understeering. All it's doing is preventing a bit of power over.
my piece of advise is whilst on the track turn the TCS OFF. then you will be able to better see what the car is doing. all sorts of things will trigger TCS which cuts your power and thus gives you no chance of figuring out what was happening.
sorry late reply
thanks for all the help guys.... i have a feeling it maybe just a bit too much throttle on exit, or too much too early. R34 turbo's have factory LSD's as far as i know.
i might read into it a bit more, but yeah, as some of you have said, probably the best thing is some seat time.
oh, i am guilty of the late gear change too :starwars: did notice that does a nice job of unsettling the car during heavy braking :D
slightly OT, but if you have full adjustable sway bars, strut braces front/rear, is there anything else that can be done to reduce body roll? just out of curiosity.... i guess that leaves only a roll cage?
sorry late reply
Why do you think it has too much roll?
Cheers
Gaery
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
